PIX Management Center problem
mingchieh
Level 2
Level 2
Hello!!
When I use the Pix MC 1.2 , there are no
group object on the Device menu , So I
can not Import any Pix , Why ??
Anything Wrong ??
awaheed
Hi Ming,
I am not sure how you cannot add the PIX in this case, it should be under "Devices > Importing Devices" or you can try importing the Config file if not the PIX itself and then see how that works for you. For further help check: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mgt_pix/fwmc12/ug/net_asst.htm#1094007
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
