pix monitor mode help
scott.hammond
trying to upgrade an old pix as a migration for getting some asa's installed.
it doesnt have enough flash to do the upgrade straight up so I have to do it from monitor mode, trouble is I cant get it into monitor mode.
I have read at least 20 threads about how you press escape and how it even says "press escape" during the boot process but this one must be older and doesnt have that option.
tried every hyperterm/secure crt break sequence I can think of and there is no joy. Anybody have any suggestions?
webhost# reload
Proceed with reload? [confirm]
Rebooting....
Cisco Secure PIX Firewall BIOS (3.6)
Booting Floppy
Flash=i28F640J5 @ 0x300
Reading 1937920 bytes of image from flash.
128MB RAM
mcwa i82559 Ethernet at irq 11  MAC: 00d0.b792.5897
mcwa i82559 Ethernet at irq 10  MAC: 00d0.b792.5695
mcwa i82558 Ethernet at irq  9  MAC: 00e0.b601.86de
mcwa i82558 Ethernet at irq  9  MAC: 00e0.b601.86dd
mcwa i82558 Ethernet at irq 11  MAC: 00e0.b601.86dc
mcwa i82558 Ethernet at irq 10  MAC: 00e0.b601.86db
BIOS Flash=AT29C257 @ 0xfffd8000
                         c i s c o S y s t e m s
                        Private Internet eXchange
                        Cisco PIX Firewall
Cisco PIX Firewall Version 6.3(3)
Licensed Features:
Failover:                    Enabled
VPN-DES:                     Enabled
VPN-3DES-AES:                Enabled
Maximum Physical Interfaces: 6
Maximum Interfaces:          12
Cut-through Proxy:           Enabled
Guards:                      Enabled
URL-filtering:               Enabled
Inside Hosts:                Unlimited
Throughput:                  Unlimited
IKE peers:                   Unlimited
This PIX has an Unrestricted (UR) license.
  ****************************** Warning *******************************
  Compliance with U.S. Export Laws and Regulations - Encryption.
  This product performs encryption and is regulated for export
  by the U.S. Government.
  This product is not authorized for use by persons located
  outside the United States and Canada that do not have prior
  approval from Cisco Systems, Inc. or the U.S. Government.
  This product may not be exported outside the U.S. and Canada
  either by physical or electronic means without PRIOR approval
  of Cisco Systems, Inc. or the U.S. Government.
  Persons outside the U.S. and Canada may not re-export, resell
  or transfer this product by either physical or electronic means
  without prior approval of Cisco Systems, Inc. or the U.S.
  Government.
  ******************************* Warning *******************************
Copyright (c) 1996-2003 by Cisco Systems, Inc.
                Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
....................................web-dmz interface address added to PAT pool
OutsideTWT interface address added to PAT pool
Cryptochecksum(unchanged): 4af061fe 79f14d45 53777955 2d769494
Type help or '?' for a list of available commands.
webhost>
Parminder Sian
Hi Scott,
Try this:-
Appliances without a Floppy Drive (Monitor Mode)
PIX devices that do not have an internal floppy drive come with a ROM       boot monitor program that is used for the upgrade of the PIX Firewall image.       Complete these steps in order to enter monitor mode on devices without a floppy       drive:
  1. Power cycle or reload the PIX. During bootup, you are prompted to             use BREAK or ESC to interrupt Flash boot. You have ten seconds to interrupt the             normal boot process.
  2. Press the ESC key or send a BREAK character in order to enter monitor mode.
    • If you use Windows HyperTerminal, you can press the ESC key or                 send a BREAK character by with the Ctrl+Break keystroke.
    • If you Telnet through a terminal server in order to access the                 console port of the PIX, you must press Ctrl ] in order to get                 to the Telnet command prompt. Then enter the send break command.
  3. The monitor> prompt displays.
  4. Proceed to the Upgrade the PIX             Firewall from Boothelper or Monitor Mode section of this document.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a5d.shtml#
Hope this helps,
Sian
