pix os 7.0 (1) problem with static nat to claster
lanosys
I have a SMTP server on claster on inside interface of PIX and SMTP server in DMZ.
I need connect claster server with server in DMZ.
from my config
static (inside,dmz) 192.168.1.100 172.17.2.5 netmask 255.255.255.255
static (inside,dmz) 192.168.1.101 172.17.2.101 netmask 255.255.255.255
static (inside,dmz) 192.168.1.102 172.17.2.102 netmask 255.255.255.255
192.168.1.4 - ip addres of SMTP server in DMZ
172.17.2.5 - ip addres logical interface SMTP in inside
172.17.2.101 - ip addres phisical interface SMTP in inside
172.17.2.102 - ip addres phisical interface SMTP in inside
but
telnet from 192.168.1.4 to 172.17.2.5 25 don't work!
tel me please Why???
this config in pix os 6.3 work!
harishtandon23
Hello Ianosys,
Please try to telnet from 192.168.1.4 to 192.168.1.100 25 instead..
As we are trying to telnet from the dmz server, and we need to telnet to the translated ipaddress of the inside server instead of the physical ip address of inside server.
If you have any questions, please feel free to contact me.
Thanks & Regards,
Harish Tandon
harishtandon23@gmail.com
thank you for answer.
I mystaped.
telnet from 192.168.1.4 to 192.168.1.100 25 don't work
new info:
if a SMTP server in DMZ is not cluster and have 1 physical Ethernet interface - all work fine with my config. (I put test server instead cluster).
maybe packets blocking with any new antispoofing mechanism of PIX OS 7.0 ???
