PIX Outside and Inside using the same network ID
adisegna
How can I give my DMZ interface an ip address on the same network of my external inteface?
I am trying to configure the PIX with an ISA server on the DMZ interface.
Thanks in advance.
mlowery
Level 2
Level 2
I don't believe you can do that unless you are using the 7.0 code. It says that you can bridge with that firmware, but I don't have a PIX capable of running it, so I can't tell you for sure.
I don't know of anyway to do it with 6.3(4).
johansens
Level 9
Level 9
Yeah that's why I do currently. I'm just having issues with the ISA 2004 denying traffic. I can't put my finger on the problem yet.
I'm routing the traffic through to the DMZ interface
Static + ACL is defined to allow everything in from outside to DMZ. Should I set the static to be:
static (DMZ,outside) pub.ip.add int.ip.add 0 0 norandomseq
or
static (DMZ,ouside) pub.ip.add pub.ip.add 0 0 norandomseq
access-list permit_in permit any host pub.ip.add
access-group permit_in in interface outside
Is anyone using a ISA 2004 server behind a PIX and publishing internal servers?
You could try something like this:
static (DMZ,outside) pub.ip.add dmz.ip.add netmask 255.255.255.255
nat (DMZ) 2 dmz.ip.add 255.255.255.255
global (outside) 2 pub.ip.add
access-list outside-in permit ip any host pub.ip.add
access-list dmz-in deny ip host dmz.ip.add internal.ip.networks internal.ip.netmasks
access-list dmz-in permit ip host dmz.ip.add any
access-group outside-in in interface outside
access-group dmz-in in interface dmz
The ISA-server should then have the IP-address dmz.ip.add on it's interface in the DMZ. This is of course not the public IP-address... 🙂
