PIX to PIX Tunnel Issue - HELP !!!!
admin_2
Level 3
Level 3
I have verified my keys are correct....I think the DSL provider on one of my PIX's is blocking port 500. Any help/ ideas would be greatly appreciated...I copied a debug crypto isa 2 log...I'm at a stand still...
Total : 1
Embryonic : 1
dst src state pending created
204.238.xx.xx 68.xx.xx.xx MM_KEY_EXCH 0 0
VPN Peer:ISAKMP: Peer Info for 204.238.xx.xx/500 not found - peers:0
crypto_isakmp_init_phase1_fields: initiator
construct_header: message_id 0x0
construct_isakmp_sa: auth 1
ISAKMP (0): beginning Main Mode exchange
crypto_isakmp_process_block:src:204.238.xx.xx, dest:68.xx.xx.xx spt:500 dpt:500
OAK_MM exchange
oakley_process_mm:
OAK_MM_NO_STATE
process_isakmp_packet:
process_sa: mess_id 0x0
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 1 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash MD5
ISAKMP: default group 1
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are acceptable. Next payload is 0
crypto_generate_DH_parameters: dhset 0xeab84c, phase 0
DH_ALG_PHASE1
process_isakmp_packet: OAK_MM
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
construct_ke:
need_cert_from_peer:
construct_nonce:
construct_xauthv6_vendor_id:
construct_dpd_vendor_id:
construct_unity_vendor_id:
construct_vendor_id:
return status is IKMP_NO_ERROR
OAK_MM exchange
oakley_process_mm:
OAK_MM_SA_SETUP
process_ke:
ISAKMP (0): processing KE payload. message ID = 0
crypto_generate_DH_parameters: dhset 0xeab84c, phase 1
DH_ALG_PHASE2
process_nonce:
ISAKMP (0): processing NONCE payload. message ID = 0
process_vendor_id:
ISAKMP (0): processing vendor id payload
process_udp_enc_vendor_id:
process_vendor_id:
ISAKMP (0): remote peer supports dead peer detection
process_vendor_id:
ISAKMP (0): speaking to another IOS box!
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
construct_hash:
compute_hash:
ISAKMP (0): retransmitting phase 1 (0)...
ISAKMP (0): retransmitting phase 1 (1)...
ISAKMP (0): deleting SA: src 68.xx.xx.xx, dst 204.238.xx.xx
ISADB: reaper checking SA 0xeab594, conn_id = 0 DELETE IT!
shannong
Level 4
Level 4
We can see that the two devices successfully negotiated ISAKMP parameters. Therefore, I would assume that UDP/500 is not blocked.
Do the firewalls connect to each other via NAT? If so, I would try enabling NAT-T on your firewall.
[isakmp nat-traversal]
I'm having the exact same issue. I'm using IOS ver 6.2(1).
Does anyone have any ideas?
