PIX upgrade problem
mcam
Community Member
I upgrated a PIX 515 UR from 6.3(1) to 7.0(1) with 64 Mo SDRAM only...
Now, the pix boots only in monitor mode
I have tried to upgrade to 6.0(4), 6.3(4) from monitor, I always get the following error :
Cisco Secure PIX Firewall admin loader (3.0) #0: Tue May 21 08:28:23 PDT 2002
Flash=i28F640J5 @ 0x300
BIOS Flash=AT29C257 @ 0xd8000
imgsum_config: sumval(0xe78d) md5(0xdf5c6c16 0xc94560f4 0x9ecc23cc 0x01c591f0)
imgsum_verify: chksum(0x7878) md5(0xdf5c6c16 0xc94560f4 0x9ecc23cc 0x01c591f0)
Checksum verification on flash image failed.
The md5 checksum are ok on tftp server...
Somebody could help me ?
Thanks for you help.
a.alekseev
Level 11
Level 11
You need order SDRAM for PIX to run 7.0
After that you can downgrade to 6.3
sgoumans
Community Member
first off you need to check your Prerequisites to upgrading.
515 UR licence needs 128megs refer to the Guide for Cisco Pix 6.2 and 6.3 Users Upgrading to Cisco PIX Software Version 7.0 on page 62
should solve your problem
