Point To Point Issue With ASA 5505
DMaluta69
I recently had a Cisco ASA 5505 firewall installed by a consulting company. I have two offices, the main one (192.168.1.*) and one (192.168.151.*) connected via a point to point router. The issue I'm having is I am unable to ping the computers behind the offsite router. Users at the offsite location CAN ping to our servers on our network using either DNS or IP address, but we cannot ping from the main office to the offsite location. I need to install a network printer, located at the offsite office, on one of the servers in the home office. I cannot do that since I can't get past the router. The following is the configuration on the router. The ASA 5505 has a base license with 3 Vlans and 8 physical interfaces. Any help would be greatly appreciated....
: Saved
ASA Version 8.2(5)
hostname
domain-name
enable password
passwd
names
name 192.168.151.111 ERouter
name 192.168.1.111   RRouter
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.1.2 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 173.15.90.173 255.255.255.252
boot system disk0:/asa825-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
 domain-name ******.org
same-security-traffic permit intra-interface
object-group network obj_any
object-group network mail143
object-group network mail110
object-group network mail25
object-group network rdptsserver
object-group network 192.168.1.13
object-group service 3389
 service-object tcp source eq 3389
object-group network 192.168.1.15
object-group service 25
 service-object tcp source eq smtp
object-group service 110
 service-object tcp source eq pop3
object-group service 143
 service-object tcp source eq imap4
object-group service 21
 service-object tcp source eq ftp
object-group service https
object-group service 80
 service-object tcp source eq www
object-group service 993
 service-object tcp source range 1 65535
object-group network 192.168.1.0
object-group network 192.168.151.0
object-group service HTTP-port
object-group service HTTPS-port
 service-object tcp source eq https
object-group service FTP-port
object-group service TCP-993
 service-object tcp source eq 993
object-group network Inside-192.168.151.0
object-group network Inside-192.168.1.0
object-group service UDP-5632
 service-object udp source eq pcanywhere-status
object-group service TCP-5631
 service-object tcp source eq pcanywhere-data
object-group network 10.0.3.0
object-group network 10.0.33.0
object-group network VPN-out-test
object-group network VPN-test
object-group service DM_INLINE_TCP_2 tcp
 port-object eq 3389
 port-object eq ftp
 port-object eq pcanywhere-data
 port-object eq ssh
object-group service DM_INLINE_SERVICE_1
access-list outside_access_in extended permit tcp any host 192.168.1.13 object-group DM_INLINE_TCP_2
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit udp any host 192.168.1.13 eq pcanywhere-status
access-list outside_access_in extended permit tcp any interface outside object-group DM_INLINE_TCP_2
access-list outside_access_in extended permit udp any interface outside eq pcanywhere-status
access-list outside_access_in extended permit ip any any
access-list outside_1_cryptomap extended permit ip 10.0.33.0 255.255.255.0 10.0.3.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.151.0 255.255.255.0 10.0.3.0 255.255.255.0
access-list cap extended permit udp host 10.0.3.233 host 192.168.1.15
access-list cap extended permit udp host 192.168.1.15 host 10.0.3.233
access-list VPN_NAT extended permit ip 192.168.1.0 255.255.255.0 10.0.3.0 255.255.255.0
access-list u-turn extended permit ip 192.168.1.0 255.255.255.0 192.168.151.0 255.255.255.0
access-list u-turn extended permit ip 192.168.151.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list test extended permit ip host 192.168.1.15 host 192.168.151.10
access-list test extended permit ip host 192.168.151.10 host 192.168.1.15
access-list test2 extended permit ip host 192.168.1.10 host 192.168.151.10
access-list test2 extended permit ip host 192.168.151.10 host 192.168.1.10
access-list nat_exempt extended permit ip 192.168.151.0 255.255.255.0 10.0.3.0 255.255.255.0
access-list U_TURN extended permit ip 192.168.1.0 255.255.255.0 192.168.151.0 255.255.255.0
access-list inside_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list inside_access_in extended permit ip 192.168.151.0 255.255.255.0 any
access-list NONAT extended permit ip 192.168.1.0 255.255.255.0 192.168.151.0 255.255.255.0
access-list NONAT extended permit ip 192.168.151.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 20
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool L2TP 192.168.2.1-192.168.2.10 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-702.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 3389 192.168.1.13 3389 netmask 255.255.255.255
static (inside,outside) tcp interface smtp 192.168.1.15 smtp netmask 255.255.255.255
static (inside,outside) tcp interface pop3 192.168.1.15 pop3 netmask 255.255.255.255
static (inside,outside) tcp interface imap4 192.168.1.15 imap4 netmask 255.255.255.255
static (inside,outside) tcp interface https 192.168.1.15 https netmask 255.255.255.255
static (inside,outside) tcp interface ftp 192.168.1.13 ftp netmask 255.255.255.255
static (inside,outside) tcp interface 993 192.168.1.15 993 netmask 255.255.255.255
static (inside,outside) tcp interface pcanywhere-data 192.168.1.13 pcanywhere-data netmask 255.255.255.255
static (inside,outside) tcp interface 5632 192.168.1.13 5632 netmask 255.255.255.255
static (inside,outside) tcp interface ssh 192.168.1.13 ssh netmask 255.255.255.255
static (inside,outside) tcp interface www 192.168.1.9 www netmask 255.255.255.255
static (inside,outside) 10.0.33.0  access-list VPN_NAT dns
static (inside,outside) 10.0.3.0 10.0.3.0 netmask 255.255.255.0 dns
static (inside,outside) 192.168.151.0  access-list nat_exempt dns
static (inside,inside) 192.168.151.0 192.168.151.0 netmask 255.255.255.0 dns
static (inside,inside) 192.168.1.0  access-list U_TURN dns
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 173.15.90.174 1
route inside 192.168.151.0 255.255.255.0 RRouter 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
sysopt noproxyarp inside
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 216.86.155.60
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 30
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto isakmp policy 50
 encryption 3des
 hash sha
 group 2
 lifetime 28800
crypto isakmp nat-traversal 1500
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 999
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
 dns-server value 192.168.1.15 192.168.1.8
 vpn-tunnel-protocol IPSec l2tp-ipsec
username microtech password r1uIvMipDbYNFVjQrVBRBw== nt-encrypted
tunnel-group 216.86.155.60 type ipsec-l2l
tunnel-group 216.86.155.60 ipsec-attributes
 pre-shared-key *****
class-map u-turn
 match access-list u-turn
class-map type inspect dns match-any testmap
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect dns
 class u-turn
  set connection advanced-options tcp-state-bypass
policy-map type inspect dns migrated_dns_map_1
 parameters
  message-length maximum 512
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:3dfe7685e63d2f6386ad5b9b08b06616
: end
asdm location RRouter 255.255.255.255 inside
asdm location ERouter 255.255.255.255 inside
7 Replies 7
Gabriel Hill
Hello Daniel,
Is your setup like this? : ASA (Mainsite)  ------- (Other site) Router
Your ASA is allowing everything coming in "access-list outside_access_in extended permit ip any any" so it makes sense that the offsite could ping your main site.
(o
utside_access_in is tied to your outside interface).
Could you post the routers configuration from the other site?
Gabriel
Hi Gabriel,
Unfortunately, I don't have access to the setup on the point to point routers.
Setup is like this... Internet -----  ASA  ------ Local Site ------ Offsite Location. The local site and the offsite location are connected via a point to point connection. The offsite location gets their internet and e-mail via this point to point connection. They are not having problems with either.
That's what's confusing me. They have internet, can access their e-mail but cannot reach shared directories on our subnet. The point to point setup has not changed. The connection was working fine when we were using a SonicWall TZ100 firewall. The consulting company convinced us to go with the Cisco in order to create a VPN to a hosted e-mail server. Since the Cisco was configured we've had issues with connectivity to the offiste location.
Wouldnt the traffic in your situation go like this
Remote Site connecting to the Internet
  • Hosts connections route through the Point to Point connection to your central site
  • Central site router fowards traffic to the ASA with default route
  • ASA routes traffic to Internet
  • Return traffic is statictly routed back towards the remote site
Remote Site connecting to the Central Site
  • As the point to point connections Central Site router has the central sites LAN network directly connect to it, it will forward the traffic straight to the LAN servers
  • The LAN Servers will however forward the traffic to the default gateway which is probably ASA?
  • ASA would normally block these connections as it hasnt seen the initial TCP connection forming but in your case it seems you have configured the TCP State bypass.
If you ask me it would be better if your Point to Point connection first came to the ASA firewall on its own interface and only from there connected to the Central Site LAN network.
I dont know if it would help with the situation but it certainly would make the network setup a lot simpler for the ASA and its configurations. Also it would remove the asymmetric routing thats happening now.
If you only have Base License on the ASA then it would not be possible to configure the third Vlan interface to the ASA.
EDIT: Bah read wrong again. The problem is actually getting connections through from Central to Offsite/Remote site
- Jouni
Hi Jouni,
Yes, the traffic pattern you describe is what happens here.
Oh gotcha. So the ASA isn't going over its outside interface to reach the local site, my bad.
Just to better my understanding is this the layout?
Internet --- ASA --- (192.168.1.111) RRouter  <------>  ERouter (192.168.151.111 )
I noticed the NONAT isn't added globally. I would goahead and add this statement (doubt it will change your situation as I am not
a 100% how your routing works at this point).
nat (inside) 0 access-list NONAT
It seems like you have some async routing. Is your ASA the default gateway for everything on the 192.168.1.0 subnet?
For the 192.168.151.0 subnet to talk with the 192.168.1.0 subnet does it end up speaking to the ASA?
Gabriel,
The layout you have is correct.
Yes, the ASA is the default gateway for everyone on the 192.168.1.0 subnet. I'm unsure if the  192.168.151.0 subnet speaks to the ASA.
I have a terminal server in the home office that the users at the offsite location log into. They are able to do so without any issues.
DMaluta69
Okay, I upgraded our license to Security +  Here's my updated running configuration. We are still unable to ping devices behind the 192.168.151.111 router. I've tried connecting the point to point connection directly to the 5505 but that didn't make a difference. Not really sure where things are going wrong. Do I need to create another VLan (now that I have the upgraded license) to account for the offsite point to point connection?
Network map is:
Internet ----> Cisco 5505 ------->  R-Router with the E-Router connected to a switch on the R-Router network segment.
: Saved
ASA Version 8.2(5)
hostname
domain-name
enable password
passwd
names
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
ftp mode passive
 domain-name local881ufcw.org
 port-object eq 3389
 port-object eq ftp
 port-object eq ssh
pager lines 20
mtu inside 1500
mtu outside 1500
no failover
arp timeout 14400
route inside 192.168.151.0 255.255.255.0 RosemontRouter 1
http server enable
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 28800
telnet timeout 999
ssh timeout 5
console timeout 0
webvpn
class-map u-turn
  inspect dns
 class u-turn
 parameters
Cryptochecksum:7f9d3eb8d201b7411e4e2434f4c537ba
: end
