Polling snmp oid for power supply on cisco 2140
vgershman
I am not able to run snmp walk command for power supply and fan status against Cisco 2140 firewall. I use 1.3.6.1.4.1.9.9.826 oid.
marce1000
       - What does 'not able' mean = what are your results ?
 M.
I get "no such object available"
  - Usually means that the OID and or feature is not (yet) implemented you may verify using :
                 > system support diagnostic-cli
  firepower# show snmp-server oid
  or stuff like :
firepower# connect fxos
firepower(fxos)# show snmp internal oids supported
 M.
ok. got it. will check that. thanks
