Port Forwarding Help
andrewgarlick
Community Member
I have a couple of ASA 5505's which work fine for what they are doing VPN and all that - we have 1 DLINK DFR-700 Firewall left and I need to get a new ASA to replace this since it is old.
All this box really does is port forward external clients to 1 address on the internal lan for client software updates.
So my question is since I have never really done this is does anybody have any example configs
So lets say we have client a with IP 1.1.1.1 and client b has 2.2.2.2 - at the moment this is what happens client a and b come in through http and get mapped to the internal http server 10.10.1.2
So I need to setup about 100 clients which can come in through http only - get mapped to the internal IP and also keeping the internal server to be able to access anything outside.
Make sense?
Any help would be great - thanks
varrao
Level 11
Level 11
Hi Andrew,
If I understand you configuration correctly, you've got close to about 100 clients on the outside, which needs to be connected to your internal http server, so I assume your network topology is something like this:
outside----------ASA-------------inside
(clients)                             (server)
Now to publish this particulatr server to the outside world , you would need to map it to a public ip address, lets say 100.100.100.100
and if you do not have a free IP address, you can use static port forwarding (which would only use a single potrt, instead of the whole IP address).
static (inside,outside) tcp 100.100.100.100 443 10..10.10.10.10 443
Along with that you would need to allow access to clients by applying an access-list on the outside interface.
access-list outside_access extended permit tcp ho 1.1.1.1 ho 100.100.100.100
access-group outsidfe_access in interface outside
To give access to the internal users for the internet, you need the following rules:
nat (inside) 1 0 0
global (outside) 1 interface
The complete internal users would be patted to your outside interafce of the ASA.
Here is a document for ASA NAT/PAT:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008046f31a.shtml
Let me know if this was wat you were looking out for.
Varun Rao
Varun Rao
