Port forwarding problem
henry9876
Community Member
Hello all, looking for some assistance.
I am simply trying to grant RDP access from the outside Internet to an internal host -- 10.0.11.254 -- on the inside-2 network. The config below is edited, but I think I have all the relevant pieces in there.
Thanks for taking a look!
: Saved
: Written by enable_15 at 20:17:55.312 UTC Wed Jul 11 2012
ASA Version 8.2(1)
name 170.1.1.1 WAN-IP
interface Vlan1
nameif inside
security-level 100
ip address 10.0.3.2 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address WAN-IP 255.255.255.248
interface Vlan3
nameif inside-2
security-level 100
ip address 10.0.11.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
switchport protected
speed 100
duplex full
interface Ethernet0/1
speed 100
duplex full
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
speed 100
duplex full
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service rdp tcp
description for port 3389
port-object eq 3389
access-list outside_rdp_in extended permit tcp any interface outside eq 3389
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (inside-2) 1 0.0.0.0 0.0.0.0
static (inside-2,outside) tcp interface 3389 10.0.11.254 3389 netmask 255.255.255.255
static (inside,inside-2) 10.0.3.0 10.0.3.0 netmask 255.255.255.0
static (inside-2,inside) 10.0.11.0 10.0.11.0 netmask 255.255.255.0
access-group outside_rdp_in in interface outside
route outside 0.0.0.0 0.0.0.0 170.1.1.2 1
dynamic-access-policy-record DfltAccessPolicy
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
: end
Your NAT and ACL is in place. That looks good. Pleas post the output of the following command:
packet-tracer input outside tcp 1.2.3.4 1234 170.1.1.1 3389
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Thank you, Karsten.
NOTE: The address 170.1.1.1 is not actual address. For the packet-trace, I replaced with actual outside address and the output follows.
ciscoasa# packet-tracer input outside tcp 1.2.3.4 1234 17x.x.x.x 3389
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match tcp inside-2 host 10.0.11.254 eq 3389 outside any
    static translation to WAN-IP/3389
    translate_hits = 0, untranslate_hits = 1
NAT divert to egress interface inside-2
Untranslate WAN-IP/3389 to 10.0.11.254/3389 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (inside-2,inside) inside-2-network inside-2-network netmask 255.255.255.0
  match ip inside-2 inside-2-network 255.255.255.0 inside any
    static translation to inside-2-network
    translate_hits = 101, untranslate_hits = 249
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1556762, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside-2
output-status: up
output-line-status: up
Action: allow
Do you have somekind of LAN to LAN VPN configurations on the ASA or why is the packet-tracer giving a Phase for VPN also?
- Jouni
Yes, there are several LAN-to-LAN VPN tunnels. I cut those out of the posted config because I thought it wasn't relevant and it has a lot of public IPs + other revealing info.
I can edit and post it if you feel that it would be helpful.
I have some suspicion that the RDP request from outside is not even getting to the ASA. There is a "gateway" from our cable internet provider in front of the ASA, which might be doing some filtering. I will check that.
