Port Forwarding Problem
reseauxjcnet
Community Member
This is my first time working with Cisco routers and I'm setting up a brand new 1812 with IOS 12.4.
I  used CCP to configure it including the ZFW with DMZ on 10.10.3.1. Traffic flows from  in to out but now I need to open some ports for inbound ssh traffic. I  want connections on port 29 to be directed to a specific  machine 10.10.0.199 on the inside. CCP didn't add any inbound rules so  I'm trying to figure this out by hand but it's not working.
I'm not sure where to start asking questions so let  me start with the following and hopefully someone can point me in the  right direction or at least get the discussion going.
Now, it looks to me that I should be using port mapping so I've added the following (via CCP):
ip port-map user-ssh-29 port tcp 29 list 3
access-list 3 permit 10.10.0.199
From discussions I've read on this forum and around the net I'm seem to be missing some NAT rule(s). Something like
ip nat inside source static tcp 10.10.0.199 29 interface FastEthernet0 29
The rules that were created are:
class-map type inspect match-any user-ssh-29
match protocol user-ssh-29
class-map type inspect match-all ccp-cls--1
match class-map user-ssh-29
match access-group name incoming-abc
ip access-list extended incoming-abc
remark CCP_ACL Category=128
permit ip any host 10.10.0.199
The  net effect is that inbound connections are not getting through, they  don't fail with a connection refused, but they hang waiting ...
Using the CCP monitoring features it looks like the  router is taking these connection attempts to be outside->self rather  than outside->inside as the the packets show up in Firewall Status  out->self dropped packets monitor
The 1812's outside interface in on a subnet 10.10.2.0 behind a DSL modem/router.
For port forwarding you need the NAT rule you mentioned:
The above command says that when the router receives an inbound TCP packet on port 29 on its FastEthernet interface, it will redirect it to 10.10.0.199 on the same port.
If you have an ACL applied to this FastEthernet interface, the ACL should permit this traffic in.
Federico.
I've been away ... but still need help. I know that I'm missing something.
What exactly would ACL look like? I've tried a number of things that haven't worked.
In order to understand this stuff I've stripped it down to the below, having removed the fw parts. Outgoing is ok but the incoming map on port 29 doesn't work. The debug trace produces stuff like this:
NAT*: o: tcp (10.10.0.100, 37237) -> (10.10.0.8, 29) [0]
NAT*: s=10.10.0.100, d=10.10.0.8->10.10.5.20 [0]
NAT*: i: tcp (10.10.5.20, 29) -> (10.10.0.100, 37237) [14190]
NAT*: s=10.10.5.20->10.10.0.8, d=10.10.0.100 [14190]
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname gw1
boot-start-marker
boot-end-marker
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip domain name xx.com
ip name-server 10.10.0.5
no ipv6 cef
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip address 10.10.0.8 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 10.10.5.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.0.5 permanent
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 10.10.5.20 29 interface FastEthernet0 29
ip nat inside source list 1 interface FastEthernet0 overload
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.5.20 0.0.0.255
no cdp run
control-plane
end
