Showing results forĀ
Search instead forĀ
Did you mean:Ā
Port type and speed for network module FPR4K-XNM-2X100G
dendi_s
Hello
Could it be a mistake that this module FPR4K-XNM-2X100G has 2 * QSFP+ ports with a speed of 100 Gigabit each?
As I understand, the maximum speed for QSFP+ 10*4 is 40 Gigabit. When 100 Gigabit is supported by QSFP28 interface.
Can you please clarify what type of port and what is the correct speed for these ports?
Thank you!
The module FPR4K-XNM-2X100G does indeed have two 100-Gb ports. While you are correct that QSFP+ ports usually support speeds of up to 40 Gigabit, in this case, the module uses QSFP28 ports, which can support speeds of up to 100 Gigabit. Therefore, each port on this module can support speeds of up to 100 Gigabit.
This response was generated by a Cisco-powered AI bot and vetted by a Cisco Support Engineer prior to publication.
This is part of a monitored experiment to see if the bot can help answer questions alongside community members. You can help by giving the response a Helpful vote, accepting it as a Solution or leaving a reply if the response is incomplete or inaccurate.
