10-08-2012 10:10 AM - edited 03-11-2019 05:06 PM
One of the interface on the primary fails and it switchover to secondary, this is happening with the primary firewall with irregular intervals, the ABC interface is a sub-interface and is connected to DMZ switch configured as a trunk. No other SUB-interfaces are failing except ABC interface and the failover switchovers to secondary firewall. As per the cisco documentation it is network problem but the DMZ switches are OK ,no errors in the sh logging , How can i troubleshoot such problem.
: %ASA-1-105005: (Primary) Lost Failover communications with mate on interface ABC
: %ASA-1-105008: (Primary) Testing Interface ABC
%ASA-1-105009: (Primary) Testing on interface ABC Failed
: %ASA-1-104002: (Primary) Switching to STNDBY - Interface check
: %ASA-1-104004: (Primary) Switching to OK.
RG
Solved! Go to Solution.
10-10-2012 12:46 PM
Anybody can help me for the above query.
10-10-2012 12:56 PM
Hello Clark,
We will need to take the logs from both the switch and the ASA's so we can determine what is causing the outage.
But until the issue happens again we will not be able to determine the issue,
Julio
10-10-2012 01:26 PM
Julio thanks for all your support and i appreciate your patients to answer my thread and queries.
God bless you.
On standby unit
10-12-2012 03:38 AM
Hi,,
i have noticed on Primary ASA when it is active many interfaces are losing connecton same as ABC interface but other interface such as inside and DMZ testing is passed only interface ABC testing is failed and then it switchovers.
ASAFW : %ASA-1-105005: (Primary) Lost Failover communications with mate on interface INSIDE
ASAFW : %ASA-1-105008: (Primary) Testing Interface INSIDE
ASAFW : %ASA-1-105009: (Primary) Testing on interface INSIDE Passed
ASAFW : %ASA-1-105005: (Primary) Lost Failover communications with mate on interface DMZ
ASAFW : %ASA-1-105008: (Primary) Testing Interface DMZ
ASAFW : %ASA-1-105009: (Primary) Testing on interface DMZ Passed
ASAFW : %ASA-1-105005: (Primary) Lost Failover communications with mate on interface ABC
ASAFW : %ASA-1-105008: (Primary) Testing Interface ABC
ASAFW : %ASA-1-105009: (Primary) Testing on interface ABC Failed
ASAFW : %ASA-1-104004: (Primary) Switching to OK.
