Problem accessing another public ip in same subnet
erik.gunstad
Community Member
I have searched around for a previous post regarding this but can't find an issue similar to mine (or I'm just too stupid to understand that it is )
I have a Cisco 5505 at a small business that I help. The problem is that the ISP are providing public IPs to multiple customers in a /24 subnet. The ASA has a single public IP configured 8.8.8.8 (not really, just for the examples sake) with a subnet mask of 255.255.255.0.
The webserver I have to access is not managed by me and is located in a different location (same town though) has 8.8.8.115, it is located in the same subnet as the ASA.
How would I make this work? I have tried to configure a static arp entry for the web server but it just won't work. If i place a computer directly on the outside interface I have no problem accessing the web server.
I am running ASA version 8.2, but I could upgrade if it would help me solve the problem.
Any help with this issue is much appreciated.
Erik
The mac address reported in the ARP colliision message, is that the same mac address shown in the arp cache on the ASA ?
Jon
16 Replies 16
Jon Marshall
Erik
Could you clarify the topology in relation to the ASA and the web server ie.
1) is the web server protected by the ASA
2) what interface has the 8.8.8.8 IP ?
3) what interface is the web server located off eg. inside, DMZ
4) are you using the real public IP on the web server or are you using a private IP and NAT ?
Jon
Thanks for your time Jon.
1. The web server is protected by another firewall that I don't know the type of since I'm not responsible for that location. It is a third party web server.
2. It's not really 8.8.8.8 (I know it is a google dns server) but just to have something to referens in this issue. It is used on the wan interface on the customers ASA.
3. The web server will be accessed via the wan interface since it is not located on the same site but share the same public subnet with my customer since their ISP gives out ip addresses from the same /24 subnet. I guess it is to save a couple of public addresses.
4. To access the web server I must use a public address since I can't access it any other way. There is no other path but via the ISP.
I think this is a ASA specific issue since the third party haven't had this issue with other firewalls and I can access the web server if I remove the ASA and puts the public address on my laptop.
I hope this clarify the issue Jon.
Erik
I'm still not getting this sorry.
You have an ASA with an outside interface of 8.8.8.8 (i know these are dummy addresses). Is that correct ?
If so the web server has an IP from the same subnet. But the real web server sits behind another firewall.
So this web server must have a different real IP ?
How is the other firewall connected to the ASA ie. which interface on the ASA ?
Jon
I know that I'm not beeing clear, It's hard to explain. I have drawn a Visio sketch that I hope clarify my issue. I have nothing to do with the third party site only the Customer site.
Once again, thanks for your time.
Erik
Okay, so if you replace the ASA with a laptop using the 8.8.8.8 IP it all works ?
So are you doing NAT for the internal clients on the ASA eg.
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
assuming the clients are connected to the inside interface.
Jon
That is correct. If i connect a laptop with the public address instead it works. Also, it works from pretty much any other place as long as you are not behind an asa on the same subnet. I can for example connect from my office.
I am doing nat
nat (inside) 0 access-list inside_VPNClients
The clients are connected to the inside interface.
Erik
What does the arp table show when you try to connect through the ASA ?
From the ASA can you ping the other firewall IP ?
Jon
The ASA has a correct ARP entry for the host.
The other firewall does not respond to pings but other host in the public subnet responds to ping.
I don't know if i matters but I do get an entry in the log viewer.
4Feb 24 201413:38:05405001
Received ARP request collision from 8.8.8.115/0003.fc04.ccbf on interface outside
Erik
Jon
Sorry, marked your anwer as correct by mistake but can't see anywhere to change it. Yes it is correct that that the mac address is the same as in my arp cache on the ASA.
Erik
Unfortunately you can't retract a correct answer mark.
Anyway, can you post the ASA config.
Also when you use the laptop with the public IP what is it's default gateway set to ?
Jon
The ISP only specify one gateway in that range and that is 8.8.8.1 so any other would not let me access internet.
Once again thank you for your time.
: Saved
ASA Version 8.2(1)
hostname ciscoasa
domain-name XXXXXXX
enable password XXXXXXX encrypted
passwd XXXXXXX encrypted
names
name 8.8.8.8 Outside_IP
name 192.168.20.2 Server
name 192.168.20.11 rav-dc01
name 192.168.20.12 rav-ms01
name 192.168.20.13 rav-rds01
interface Vlan1
nameif inside
security-level 100
ip address 192.168.20.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address Outside_IP 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa821-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name XXXXXXX
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list inside_nat0_outbound extended permit ip any 192.168.25.0 255.255.255.0
access-list RemoteVPNSplittunnel standard permit 192.168.20.0 255.255.255.0
access-list outside_access_in extended permit tcp host 100.100.100.228 interface outside eq 3389
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in extended permit udp any interface outside eq 4125
access-list outside_access_in extended permit tcp any interface outside eq 4125
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in extended permit tcp any interface outside eq pptp
access-list outside_access_in extended permit tcp any interface outside eq 444
access-list outside_access_in extended permit gre any interface outside
access-list outside_access_in extended permit udp any interface outside eq 444
access-list outside_access_in extended permit tcp any interface outside eq www
access-list inside_access_in extended permit tcp host rav-ms01 any eq smtp
access-list inside_access_in extended deny tcp any any eq smtp
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool RemoteVPNPool 192.168.25.100-192.168.25.200 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
static (inside,outside) udp interface 4125 Server 4125 netmask 255.255.255.255
static (inside,outside) tcp interface 4125 Server 4125 netmask 255.255.255.255
static (inside,outside) tcp interface https rav-ms01 https netmask 255.255.255.255  dns
static (inside,outside) tcp interface pptp Server pptp netmask 255.255.255.255
static (inside,outside) tcp interface 3389 rav-rds01 3389 netmask 255.255.255.255  dns
static (inside,outside) tcp interface smtp rav-ms01 smtp netmask 255.255.255.255
static (inside,outside) udp interface 444 Server 444 netmask 255.255.255.255
static (inside,outside) tcp interface 444 Server 444 netmask 255.255.255.255
static (inside,outside) tcp interface www Server www netmask 255.255.255.255  dns
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 8.8.8.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server rav_Intern protocol radius
aaa-server rav_Intern (inside) host rav-dc01
key CiscoAsa5505RAV2012
radius-common-pw CiscoAsa5505RAV2012
http server enable 8080
http 192.168.20.0 255.255.255.0 inside
http 192.168.25.0 255.255.255.0 inside
http 100.100.101.128 255.255.255.192 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection timewait
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
telnet 192.168.20.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.20.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 192.168.20.190-192.168.20.200 inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server rav-dc01 source inside
webvpn
group-policy RemoteVPN internal
group-policy RemoteVPN attributes
wins-server value 192.168.20.11
dns-server value 192.168.20.11
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value RemoteVPNSplittunnel
default-domain value rav.nu
split-dns value rav.nu
username SupportVPN password XXXXXXX encrypted privilege 0
username SupportVPN attributes
vpn-group-policy RemoteVPN
tunnel-group RemoteVPN type remote-access
tunnel-group RemoteVPN general-attributes
address-pool RemoteVPNPool
authentication-server-group rav_Intern
accounting-server-group rav_Intern
default-group-policy RemoteVPN
tunnel-group RemoteVPN ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect pptp
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
Cryptochecksum:8481ab3aa01b23bad17bacb2aca7197a
: end
Erik
I can't see anything obviously wrong with your config.
That ARP colliision request message does suggest an issue. It basically means the ASA is seeing the same mac address for two different IP addresses.
You could try a "debug arp" (or "debug ip arp") to see if that reveals anything.
Jon
Swaraj Nambiar
Hi Erik,
Do you have static NAT configured on the ASA?
You need to have the following configured on the ASA -
#static (inside,outside) 8.8.8.15 inside and outside are the names of the two interrfaces. I have assumed that the server is connected to the interface named "inside" and the IP 8.8.8.8 is configured on the "outside" interface.
You also need to allow this traffic in an access-list that should be applied on the "outside" interface -
#access-list inbound permit tcp any host 8.8.8.15 eq 80 --> this is assuming that "inbound" is the name of the ACL on the outside interface.
If there is no ACL applied to the outside interface, you may apply the following command as well -
#access-group inbound in interface outside
