Problem communication between two private network Cisco ASA
Beaurr
hello,
I have an ASA
with 3 interfaces configured
INSIDE ( 10.40.1.0) on Gi/2
OUTSIDE ( 10.0.0.0) on Gi/1
BIO ( 10.0.2.0) on Gi/3
Interface 3 was added by me.
I want INSIDE and BIO to communicate in FTP and ICMP in both directions.
The ASA already had an outside interface. Communication between INSIDE and OUTSIDE works (for FTP and ICMP).
I didn't originally install the ASA. OUTSIDE is connected to a router (202). It was installed by an outside contractor because in addition to the PC there is a medical analyzer.
The ASA was installed and configured by a colleague a few years ago.
I was asked to install a 3rd subnet (10.0.2.0) and to communicate, in FTP and ICMP (in both directions) between INSIDE and BIO (no need for OUTSIDE and BIO to communicate).
I don't want to modify the already existing part between INSIDE and OUTSIDE, this one is in production and functional.
But the communications between INSIDE and BIO do not work.
For my test, Gi/3 (BIO) is connected directly to a computer with the following configuration:
10.0.2.10
255.255.255.0
10.0.2.254
The configuration :
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 10.0.1.254 255.255.255.0 standby 10.0.1.208
interface GigabitEthernet1/2
nameif inside
security-level 100
ip address 10.40.1.249 255.255.255.0 standby 10.40.1.208
interface GigabitEthernet1/3
nameif bio
security-level 50
ip address 10.0.2.254 255.255.255.0
interface GigabitEthernet1/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/7
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/8
description LAN/STATE Failover Interface
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network DIPLABO
host 10.40.1.5
object network 10.0.0.201
host 10.0.0.201
object network 10.0.2.254
host 10.0.2.254
description Reseau BIO
object network 10.0.1.251
host 10.0.1.251
object-group service DM_INLINE_SERVICE_1
service-object icmp
service-object tcp destination eq ftp
object-group service DM_INLINE_SERVICE_3
service-object icmp
access-list inside_access remark permission ftp diplabo vers automate
access-list inside_access extended permit tcp 10.40.1.0 255.255.255.0 10.0.0.0 255.255.255.0 eq ftp
access-list inside_access remark Permission ping diplabo vers automate
access-list inside_access extended permit icmp 10.40.1.0 255.255.255.0 10.0.0.0 255.255.255.0
access-list inside_access remark Permission ping DIPLABO vers automate + PC1 et PC2 TEMPO
access-list inside_access extended permit ip 10.40.1.0 255.255.255.0 10.0.2.0 255.255.255.0
access-list inside_access extended permit icmp 10.40.1.0 255.255.255.0 host 10.0.1.252
access-list inside_access extended permit icmp 10.40.1.0 255.255.255.0 10.0.1.0 255.255.255.0
access-list inside_access extended permit icmp 10.40.1.0 255.255.255.0 host 10.0.1.253
access-list inside_access extended permit object-group DM_INLINE_SERVICE_3 10.40.1.0 255.255.255.0 10.0.2.0 255.255.255.0
access-list inside_access remark permission ftp diplabo == automate
access-list inside_access remark Permission ping diplabo == automate
access-list outside_access_in remark permission ftp automate == diplabo
access-list outside_access_in extended permit tcp 10.0.0.0 255.255.255.0 10.40.1.0 255.255.255.0 eq ftp
access-list outside_access_in remark permission ping automate == diplabo
access-list outside_access_in extended permit icmp 10.0.0.0 255.255.255.0 10.40.1.0 255.255.255.0
access-list outside_access_in extended permit icmp 10.0.1.0 255.255.255.0 10.40.1.0 255.255.255.0
access-list outside_access_in extended permit icmp 10.0.0.0 255.255.255.0 host 10.0.1.254
access-list outside_access_in remark permission ftp automate vers diplabo
access-list inside_nat0_outbound extended permit ip object DIPLABO any4
access-list bio_access_in remark Accès reseau Biomerieux en PING + FTP pour diplabo
access-list bio_access_in extended permit object-group DM_INLINE_SERVICE_1 10.0.2.0 255.255.255.0 10.0.0.0 255.255.255.0
access-list bio_access_in extended permit ip 10.0.2.0 255.255.255.0 10.40.1.0 255.255.255.0
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside,any) source static DIPLABO DIPLABO no-proxy-arp
nat (any,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_access in interface inside
access-group bio_access_in in interface bio
route inside 0.0.0.0 0.0.0.0 10.40.1.254 1
route outside 10.0.0.1 255.255.255.255 10.0.0.201 1
route outside 10.0.0.10 255.255.255.255 10.0.1.252 1
route outside 10.0.1.5 255.255.255.255 10.0.1.251 1
route inside 10.39.1.0 255.255.255.0 10.40.1.254 1
route inside 10.239.11.0 255.255.255.0 10.40.1.254 1
I'm not very familiar with that. Nate problem? Access List? Routing?
Thanks for your help
9 Replies 9
@Beaurr you are going to need a NAT exemption rule between your DMZ and INSIDE network.
Run packet-tracer from the CLI to simulate the traffic and provide the output for review.
You should also look to add the standby IP address to GigabitEthernet1/3.
Beaurr
packet-tracer input bio icmp 10.0.2.10 0 1 10.40.1.218
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 10.40.1.218 using egress ifc inside
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 26530, packet dispatched to next module
Phase: 7
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 11
Type: ADJACENCY-LOOKUP
Subtype: next-hop and adjacency
Result: ALLOW
Config:
adjacency Active
next-hop mac address 0050.56b6.0b27 hits 0 reference 1
Result:
input-interface: bio
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
packet-tracer input inside icmp 10.40.1.218 0 1 10.0.2.10
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
found next-hop 10.0.2.10 using egress ifc bio
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: NAT
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 6
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 26574, packet dispatched to next module
Phase: 7
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 11
Result: ALLOW
Config:
adjacency Active
next-hop mac address ecf4.bb21.ad98 hits 3 reference 1
Result:
input-interface: inside
input-status: up
output-interface: bio
output-status: up
Action: allow
For the standby, there is currently only one ASA available. The other is down.
Could you give me more details please?
Your packet tracer command is wrong,
You select the interface as input then you must config source ip and finally desntaiotn ip.
You config firdt destination ip then source ip.
Please do it right again and share the output.
My knowledge is very limited on firewalling.
Could you give me the command line?
I have come up with the below:
object network inside_10_40_1_0
subnet 10.40.1.0 255.255.255.0
object network bio_10_0_2_0
subnet 10.0.2.0 255.255.255.0
access-list DMZ_ACL extended permit icmp object bio_10_0_2_0 inside_10_40_1_0
access-list DMZ_ACL extended permit tcp object bio_10_0_2_0 inside_10_40_1_0 eq ftp
access-group DMZ_ACL in interface bio
nat (bio,inside) source static object bio_10_0_2_0 object bio_10_0_2_0 destination static inside_10_40_1_0 inside_10_40_1_0 no-proxy-arp route-lookup
object network bio-network
object network inside-network
access-list DMZ_ACL extended permit icmp object bio-network object inside-network
access-list DMZ_ACL extended permit tcp object bio-network object inside-network eq ftp
nat (bio,inside) after-auto source static bio-network bio-network destination static inside-network inside-network no-proxy-arp route-lookup   (I generated the line via asdm, it added after auto).
unfortunately, it doesn't work. I launched a continuous PING from the pc 10.02.10 towards a pc in 10.40.1..
And, a continuous PING from a pc in 10.40.1.x to 10.0.2.10 and it does not work
first you must config the ICMP inspection,
*policy-map global_policy
   class inspection_default
   inspect icmp
no need for ACL since the traffic initiate from High Security level "Inside" to low security level "DMZ"
Need NAT "without after-auto" since some ASA version do NAT for each traffic enter the Interface.
then try again ping.
Hello, thanks.
I have already this configuration :
inspect dns preset_dns_map
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
Security level is 100 for INSIDE
50 for DMZ(BIO)
I need it to work both ways
I regenerated the NAT rule
nat (bio,inside) source static bio-network bio-network destination static inside-network inside-network no-proxy-arp route-lookup
If i check the NAT rules in ASDM, I see the direction at both
AND...no ping from INSIDE to OUTSIDE
 that OK, since the ping is from the Inside to DMZ and reply from DMZ to Inside, and if there is ACL apply to DMZ then need ACL to permit the return reply to Inside.
access-list inbound permit icmp any any echo-reply
access-list inbound permit icmp any any time-exceeded
access-list inbound permit icmp any any unreachable
access-group inbound in interface DMZ
