Problem polling external interface for ASA 5510 using SNMP
Sami Abunasser
I'm having an issue polling the external interface of my firewall using SNMP. I can ping it from the poller, and the firewall is configured to allow the access, but it fails.
- Here's an excert of the configuration:
snmp-server host outside y.y.y.y community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change fru-insert fru-remove
snmp-server enable traps remote-access session-threshold-exceeded
icmp permit host y.y.y.y outside
--- y.y.y.y is the IP of the poller.
- The following is the ouput of a capture on the external interface monitoring the polling traffic:
   1: 08:25:32.946728 y.y.y.y > x.x.x.x: icmp: echo request
   2: 08:25:32.947689 x.x.x.x > y.y.y.y: icmp: echo reply
   3: 08:25:47.974665 y.y.y.y > x.x.x.x: icmp: echo request
   4: 08:25:47.974909 x.x.x.x > y.y.y.y: icmp: echo reply
   5: 08:25:55.565781 y.y.y.y.35 > x.x.x.x.137:  udp 50
   6: 08:25:57.053006 y.y.y.y.35 > x.x.x.x.137:  udp 50
   7: 08:25:58.553148 y.y.y.y.35 > x.x.x.x.137:  udp 50
- The following is the output of the logs:
Sep 21 2012 08:25:57 x-x-x-5510-01 : %ASA-7-710005: UDP request  discarded from y.y.y.y/35 to outside: x.x.x.x/137
- The following is the output of the packet tracer on the firewall:
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xac52bc28, priority=12, domain=capture, deny=false
        hits=3337268, user_data=0xab4c1c08, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xab7d4938, priority=1, domain=permit, deny=false
        hits=3756749060, user_data=0x0, cs_id=0x0, l3_type=0x8
        dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   x.x.x.x    255.255.255.255 identity
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xab7d5158, priority=0, domain=permit, deny=true
        hits=98627, user_data=0x9, cs_id=0x0, flags=0x1000, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
This issue is actually occuring on two other firewalls that i'm trying to setup external monitoring of. They are running 8.2(5).
Any assistance would be greatly appreciated.
Thank you,
Sami
nkarthikeyan
Level 11
Level 11
Hi Sami,
You should have the outbound and inbound rules allowed for the snmp ports snmp and snmp trap tpo make this work. Thats y ur packet tracer result gives its blocked by the access-list.
Please do rate if the given information helps.
By
Karthik
