Problem TFTP in pix
network
Hi Guys ,
i'm having a problem in upgrade cisco pix 515e , the follow error appear :
"Can't open tftp client "
Anybody know causes of this error ?
thanks
Jorge
12 Replies 12
John Blakley
Jorge,
What are you typing to get this error message? You didn't give us much to go on :)
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi j.blakley
this that i typing :
wr net jorgef:63.txt
Building configuration...
TFTP write '63.txt' at jorgef on interface 1
tftp: out of states
[FAILED]
Usage: write erase|floppy|mem|terminal|standby
write net []:
thanks
Jorge,
You need to specify the ip address of your tftp server. If you're running a tftp server on your laptop, for instance, and your laptop's ip address is 192.168.1.50, then your command would be:
wr net 192.168.1.50:63.txt
If you don't have a tftp server, I recommend tftpd32.
HTH,
John
hi
same error :
wr net 10.198.50.16:63.txt
tftp: out of states
[FAILED]
write net []:
jorge
Do you have a tftp server?
yes , i have a solarwinds in my pc . Others pix and routers i'm able to copy the configurations .
thanks a lot
jorge
Hmmm....try this (forgive the syntax if incorrect)
PIX(config)# tftp-server inside 192.168.1.1 63.txt
PIX# wr net
(config)# tftp-server spcbr 10.198.10.16 63.txt
(config)# wr net
TFTP write '63.txt' at 10.198.10.16 on interface 0
tftp: could not open udp/0/12345/10.198.10.16/69
[FAILED]
write net []:
Jorge,
tftp: out of states
[FAILED]
And in the last one:
Is your tftp server on the outside of the pix or the inside of the pix? Do you have an acl on the interface that you're going out on?
outside the pix
thanks a lot
If you have an acl, try adding a permit statement for udp/69.
Hi guy , the problem is the pix , when try reload , appear the follow error :
"Currently writing image. Cannot reload"
Thanks a lot
Jorge
