problem to enter from inside to dmz
In my inside network we have more than 2 vlans  and we want that the inside network access to the server that are in the dmz.
I have try many ways and i would like if some can help to understand  how i have to do it.
dmz network: 192.169.120.0 255.255.255.0
object-group LAN
172.10.10.0 /24
172.10.20.0 /24
172.10.30.0 /24
access-list Inside extended permit ip object-group LAN 192.169.120.0 255.255.255.0
access-list DMZ extended permit ip any any
access-group Inside in interface inside
access-group DMZ in interface dmz
for example we made this:
access-list INSIDE extended permit ip host 192.168.120.5 192.168.120.0 255.255.255.240
static (inside,DMZ) 192.168.120.5 172.10.10.4 netmask 255.255.255.255
the ip 172.10.10.4  pc of my inside network
witch that example y could access to dmz switch.
but when i tray to to this:
static (inside,DMZ) access-lis INSIDE  172.10.10.4 netmask 255.255.255.255
I have and error : ERROR: access-list used in static has different local addresses
Thanks for any help that can provide me.
Maykol Rojas
If you want only traffic from the inside to be initiated to the DMZ and not backwards, you can just apply a simple PAT, if the inside interface has a higher security level than the DMZ, for example:
The same NAT you have for internet access (In case you have) would be like this:
nat (inside) 1 0 0
global (outside) 1 interface
You can just add the following global
global (DMZ) 1 interface
Same as the other cases, best troubleshooting tool to check where the access is being broken,
packet-tracer input inside tcp 1025 80
That would give you the information about the packet, where and when it is being dropped.
Cheers
Mike.
Mike
Maykol Rojas
nat (inside) 1 0 0
Cheers
Mike.
Mike
Hi Mike,
I do had the same problem, and it got resolved by your answer given for this post.
Thank you Very Much
Kiran Kumar CH
Thanks for ur help.
1. So  if i want that interface that have a higher level go to a lower level  i have to  make a simple PAT   as you said,
I did what u said and works but  with that configuration  pc on the dmz can enter to inside or i have to do something else?.
2.If  i want  that only pc from dmz access to inside  what  i have to do  because i want to access from lower interface to higher interface ?
