Problem using PORT REDIRECTION with PIX 6.0(1)
r-schulz
Community Member
I am trying to setup a pair of DNS services on a
single 'box'. This would allow me to have an
INTERnet DNS and a INTRAnet DNS running on a single
server.
I thought I could accomplish this by setting the
INTRAnet function to use port 53, and the INTERnet
function to use port 2053.
Then on my PIX 6.0(1) firewall located at my network
boundary, I coded the following statement:
static (inside,outside) udp 66.123.66.123 domain 10.1.2.3 2053 netmask 255.255.255.255 0 0
Workstations using 66.123.66.123 as their DNS server
do get 'redirected' to the 2053 port O.K, but
the response to the query goes back out the firewall
on port 2053 back to the workstation. At which point, the workstation 'ignores' it become it is
expecting a response back from 'source = port 53' and not 2053.
Is there some magic I can work here, or am I stuck until it is fixed 'in the next release'?
Thank (in advance),
Dick Schulz
ciscomoderator
Administrator
Administrator
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
