problem whit PDM on PIX 506E
hfb5
when treatment to enter the PIX leaves the following error to me
Requesting URL: java.security.AccessControlException: access denied (java.util.PropertyPermission java.version read)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPropertyAccess(Unknown Source)
at java.lang.System.getProperty(Unknown Source)
at com.cisco.pdm.e.c.q(Unknown Source)
at com.cisco.pdm.e.c.h(Unknown Source)
at com.cisco.pdm.a.byte(Unknown Source)
at com.cisco.pdm.PDMApplet.start(Unknown Source)
at com.cisco.nm.util.sgz.Env.start(Env.java:37)
at com.cisco.nm.util.sgz.Loader.start(Loader.java:109)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
a.kiprawih
Level 7
Level 7
What's your current PDM version? Use 'sh ver' to verify it.
Based on Cisco field notice below, it has to do with PDM:
PIX Device Manager (PDM) versions 3.0(1) , 3.0(2), 4.0(1), and 4.1(1), and IDS Device Manager (IDM) version 5.0(1), are incompatible with Java Plug-in versions 1.4.2_08 and 1.5.0_02 or later. If these Java Plug-ins are used in conjunction with the impacted PDM or IDM releases, the application will not load.
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_field_notice09186a008046c805.shtml
Upgrade your PDM version based on the recommended workaround solution.
HTH. Pls rate all useful post(s).
AK
