Problem with an ASA.
rcapao
Level 3
Level 3
I have an ASA and I'm trying to implement something like “load sharing” between 2 ISP's.
I tried to do “dual ISP”, but that's not what I intended to have…
I tried to implement “favoring static routes based on reachability”, but I did not succeed.
Somehow this last implementation is, I think, very near of what I need. The problem with this is that it has a limitation… it doesn't let me put 2 default routes pointing to 2 different interfaces (I mean, putting the traffic that leaves the ASA in 2 different interfaces), like this:
route outside 0.0.0.0 0.0.0.0 190.3.14.5 1 track 1
route dmz3 0.0.0.0 0.0.0.0 200.100.73.11 1 track 2
Can some one help me?
Thanks in advance,
Rui
a.alekseev
Level 11
Level 11
ASA cannot do loadbalancing like a router.
You cannot have two active defalt routes. Only one will be active.
for redundancy you can use the following
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
a.alekseev
Level 11
Level 11
when you said "load balanced" you minted to say "load share", wasn't it so?
Rui Capao
