problem with asa 5505 routing,nating
mafija1975
i have the asa 5505 with asdm 6.4(5). my inside lan is 192.168.0.0/24. the outside of asa is connected on lan 10.13.74.0/24 and i need over lan 10.13.74.0/24 connect on lan 10.15.100.0/24. i puted nat rule on asa 5505 and acl rule and users from lan 10.15.100.0/24 can connect on my server, but i can't connect on from inside of asa connecet on lan 10.15.100.0/24 and 10.13.74.0/24. my configuration asa is
Result of the command: "show running-config"
: Saved
ASA Version 8.4(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.17 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.13.74.33 255.255.255.0
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network server
host 192.168.0.20
object service ParagrafLex
service tcp source eq 6190 destination eq 6190
object network sharepoint
host 192.168.0.22
access-list outside_access_in extended permit ip host 10.13.74.35 any
access-list outside_access_in_1 extended permit ip any object server
access-list outside_access_in_1 extended permit object ParagrafLex 10.15.100.0 255.255.255.0 object server
access-list outside_access_in_1 extended permit object ParagrafLex any object server
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (any,any) static 10.13.74.34
access-group outside_access_in in interface outside control-plane
access-group outside_access_in_1 in interface outside
route inside 0.0.0.0 0.0.0.0 10.13.74.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.13.74.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:791a1fa6b6fcccaa3177fed821d1f392
: end
what i do that connect on lan 10.15.100.0/24. i cant ping my outside interface, puted rules on acl, i enabled sevice policy rule for icmp ,but nothing. pleas help me
thanks
luisroja
I reviewed the configuration that you attached, and noticed that you have a static translation for one server and the Port Address Translation (PAT) for the internal host. In some cases, the NAT rules with "any,any" keywords can cause some issues with the proxy ARP feature on the ASA.
I would like to suggest you to change the following NAT rule in order to use the following:
Instead of:
Use:
nat (inside,outside) static 10.13.74.34
Use the following command to enable ICMP inspection:
fixup protocol icmp
Also, please noticed that if you are not able to ping the ASA, you should check the ARP entries of the device that is doing the routing for 10.15.100.0/24 (it seems to be that 10.13.74.1 is the default gateway of the ASA, not sure if that is the routing device that provides connectivity to 10.15.100.0/24). If such device has an ARP entry for 10.13.74.33, it should be associated with the MAC address of the outside interface of the ASA.
Another test would be to try to ping from the ASA to an IP address that belongs to 10.15.100.0/24.
After you hace changed the NAT rules, please attach the show nat detail to this post so I can check if.
Let me know the results.
Thanks.
my configuration asa 5505 is now
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
host 192.168.0.20
host 192.168.0.22
object network uzzpro
range 10.13.74.40 10.13.74.45
host 192.168.0.22
object-group network internalnetwork
network-object 192.168.0.0 255.255.255.0
object-group network uzzpro-1
network-object object uzzpro
access-list outside_access_in_1 extended permit ip any object share
access-list outside_access_in_1 extended permit icmp any object sharepoint echo-reply
access-list inside_access_out extended permit ip any any
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat (any,any) static 10.13.74.39
access-group inside_access_out out interface inside
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:cde649be1382dd8249eca185657d9de7
: end
my network configuration is: the asa 5505 connect LAN inside of asa 5505 (192.168.0.0/24) and WAN side of asa 5505 (10.13.74.0/24). the router is on 10.13.74.1. i want connect my LAN 192.168.0.0 with network 10.15.100.0. The administrator on router 10.13.74.1 is made the routes which connect two network 10.15.100.0 and 10.13.74.0. when i try ping network 10.15.100.0 from asa i can't do it. I also can't ping from my local LAN 192.168.0.0 outside interface, i can't also ping hosts on network 10.13.74.0(WAN side asa 5505). Hosts from Network 10.15.100.0 can ping NAT address of my server 10.13.74.34 and outside interface of my asa 5505.
what i do?
thanks
