Problem with ASA 5505
eduardodewes
Hello, I have an ASA 5505, firmware 7.2 (4). Configured ACLs, NAT, it's all working, but after a while it seems that running crashes, no longer makes the directions of NATs, the logs until they stop working. To resolve, I have to restart the ASA, and everything will work again. Could it be a firmware problem, someone has had a similar problem?
eduardodewes
ASA Version 7.2(4)
hostname ciscoasa
domain-name cvnatural.local
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 189.11.**.*** oi234
name 172.16.0.140 local
name 189.11.**.*** oi235 description oi235
dns-guard
interface Vlan1
nameif inside
security-level 0
ip address local 255.255.252.0
interface Vlan2
nameif outside
security-level 0
ip address oi234 255.255.255.248
interface Vlan13
shutdown
nameif inativo
security-level 0
no ip address
interface Vlan23
shutdown
no nameif
security-level 0
no ip address
interface Vlan33
shutdown
no nameif
security-level 0
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 23
interface Ethernet0/2
switchport access vlan 33
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 13
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
banner exec  CRV - ACESSO RESTRITO
banner login  CRV - ACESSO RESTRITO
banner motd  CRV - ACESSO RESTRITO
banner asdm  CRV - ACESSO RESTRITO
ftp mode passive
clock timezone BRST -3
clock summer-time BRDT recurring 2 Sun Oct 0:00 3 Sun Feb 0:00
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq ftp-data
object-group service DM_INLINE_TCP_2 tcp
port-object eq www
port-object eq https
access-list CRV_splitTunnelAcl standard permit any
access-list inside_nat0_outbound extended permit ip any 172.16.0.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.16.0.0 255.255.252.0 any
access-list inside_access_in remark DNS
access-list inside_access_in remark SMTP
access-list inside_access_in extended permit udp 172.16.0.0 255.255.252.0 any
access-list inside_access_in extended permit tcp 172.16.0.0 255.255.252.0 any
access-list inside_access_in extended permit ip 172.16.0.0 255.255.252.0 any
access-list inside_access_in extended permit ip interface outside 172.16.0.0 255.255.252.0
access-list inside_access_in extended permit tcp interface outside 172.16.0.0 255.255.252.0
access-list inside_access_in extended permit udp interface outside 172.16.0.0 255.255.252.0
access-list outside_access_in extended permit object-group TCPUDP any any eq www
access-list outside_access_in extended permit tcp any any eq 81
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any any eq https
access-list outside_access_in extended permit tcp any any eq domain
access-list outside_access_in extended permit ip 172.16.0.0 255.255.252.0 interface outside
access-list outside_access_in extended permit object-group TCPUDP 172.16.0.0 255.255.252.0 interface outside
access-list crv standard permit any
access-list outside_1_cryptomap extended permit ip 172.16.0.0 255.255.252.0 any
pager lines 24
logging enable
logging buffered alerts
logging trap alerts
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu inativo 1500
ip local pool CRV 172.16.3.150-172.16.3.160 mask 255.255.252.0
no failover
monitor-interface inside
monitor-interface outside
monitor-interface inativo
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.16.0.0 255.255.252.0
static (inside,outside) tcp interface www 172.16.0.22 www netmask 255.255.255.255
static (inside,outside) tcp interface sip 172.16.0.102 sip netmask 255.255.255.255
static (inside,outside) tcp oi235 www 172.16.0.4 www netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 189.11.**.*** 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 172.16.0.0 255.255.252.0 inside
http 201.22.57.115 255.255.255.255 outside
http 200.146.84.147 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt connection tcpmss 0
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 187.16.33.130
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal  20
crypto isakmp ipsec-over-tcp port 10000
vpn-sessiondb max-session-limit 25
telnet 172.16.0.0 255.255.252.0 inside
telnet timeout 5
ssh 172.16.0.0 255.255.252.0 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
webvpn
port 444
enable inside
group-policy CRV internal
group-policy CRV attributes
dns-server value 172.16.0.253 172.16.0.19
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
group-lock value CRV
ipsec-udp enable
ipsec-udp-port 10000
split-tunnel-policy excludespecified
split-tunnel-network-list none
nem enable
username luis password QYp.GVVJsgLuHoKE encrypted
username master password Z4lv47kJo.V6M7HB encrypted
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group CRV type ipsec-ra
tunnel-group CRV general-attributes
dhcp-server 172.16.0.253
tunnel-group CRV ipsec-attributes
pre-shared-key *
tunnel-group CRV ppp-attributes
authentication pap
authentication ms-chap-v2
authentication eap-proxy
tunnel-group 187.16.33.130 type ipsec-l2l
tunnel-group 187.16.33.130 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:14b4c4e2494f30db95c157d8727f8279
: end
Hi Eduardo,
Whenever the device stops passing traffic, I would suggest you to kindly take captures on the firewall, to check if the request is going through the ASA and if you are able to get any reply back from the ISP device. Because I had a previous experience where in the ISP device was losing the arp entries aftemr every fixed time and the resolution was to create static arp for the ASA on the ISP device.
For taking captures:
https://supportforums.cisco.com/docs/DOC-1222
Varun
Varun Rao
