problem with .cgi pages.
adriatikb
Level 3
Level 3
hello to all
i have problem with cgi pages, firewall is blloking. how can we allow that and what is the risk of doing that
thanks
didyap
Level 11
Level 11
Check if http-strict is enabled on your firewall, if it is disable it. If this does not solves the problem disable HTTP inspection and check if it is working.
didyap
Level 11
Level 11
