Problem with Cisco Secure agent instalaltion
joel
I am having problems with installing the Cisco Secure agent 5.2-203 on a RHEL 3.0 AS server.
I gives me the following error
[root@ABC CSCOcsa]# ./install_rpm.sh
Red Hat Enterprise Linux AS release 3 (Taroon Update 6)
Preparing packages for installation...
CSAagent-5.2-203
cc -DMODULE -D__KERNEL__ -Dlinux -Dkernel -I. -I/usr/src/linux-2.4/include -I../ ../../include/unix -pipe -Os -march=i686 -fno-defer-pop -fno-common -mpreferred- stack-boundary=2 -c symbols.c -o symbols.o
cc -DMODULE -D__KERNEL__ -Dlinux -Dkernel -I. -I/usr/src/linux-2.4/include -I../ ../../include/unix -pipe -Os -march=i686 -fno-defer-pop -fno-common -mpreferred- stack-boundary=2 -c fshook.c -o fshook.o
cc -DMODULE -D__KERNEL__ -Dlinux -Dkernel -I. -I/usr/src/linux-2.4/include -I../ ../../include/unix -pipe -Os -march=i686 -fno-defer-pop -fno-common -mpreferred- stack-boundary=2 -c hotpatch.c -o hotpatch.o
cc -DMODULE -D__KERNEL__ -Dlinux -Dkernel -I. -I/usr/src/linux-2.4/include -I../ ../../include/unix -pipe -Os -march=i686 -fno-defer-pop -fno-common -mpreferred- stack-boundary=2 -c adapt.c -o adapt.o
adapt.c: In function `kutil_vprintk':
adapt.c:3442: parse error before `char'
adapt.c:3443: `buf' undeclared (first use in this function)
adapt.c:3443: (Each undeclared identifier is reported only once
adapt.c:3443: for each function it appears in.)
make: *** [adapt.o] Error 1
Failed to build adaptation kernel module. Aborting
error: %post(CSAagent-5.2-203) scriptlet failed, exit status 1
./install_rpm.sh: installation failed
Would like to know where the dependancy is and what is needed to be installed for this installation to work.
Joel
TradeSecrets
Hi Joel,
The following packages are need to compile the 5.2 agent.
*GCC*
*kernel-snmp-devel*
*compat-libstdc++*
Also 5.2 error messages are alot less friendly than 5.1's
