Problem with CSA MC
reinke
Level 3
Level 3
I have installed CSA MC 4.0.1. After finishing the installation, the systems behavior is very strange:
- http access automatically changes to https (ssl).
- I get no login fields for username and password.
Any idea. It is a productive system (based on W2000). So any valuable input is highly welcome.
Edgar
jsivulka
Level 10
Level 10
You should recheck if all the system requirements including system and browser requirements have been met. Server installation requires Windows 2000 Professional, Server, or Advanced Server (Service Pack 3). The instalation guide for CSA MC is available at http://www.cisco.com/univercd/cc/td/doc/product/vpn/ciscosec/csa/40/vmsig.pdf
