problem with Destination NAT on ASAv
wikinetwork
Visitor
I am new to Asa doing practice in eve-ng with ASAv  V 9.7
in this topology i have a server inside with IP address of   192.168.1.200   and want to reach the loopback address on R2 with IP 44.44.44.44 with NAT   but i want to practice the Twice NAT (Destination NAT ) and change both source and destination .   this is configuration I have done on firewall
Object network real_inside
Host 192.168.1.200
Object network  real_outside
Host 44.44.44.44
Object network map_inside
Host 192.168.1.240
Object network map_outside
Host 10.10.14.40
nat (inside,outside) source static real_inside map_inside destination static map_inside real_outside
without NAT , destination is reachable but when apply NAT can not reach destination.
bellow is result of packet capture on ASAv
ciscoasa#packet-tracer input inside icmp 192.168.1.200 0 0 44.44.44.44
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 10.10.14.4 using egress ifc outside
Phase: 2
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
Phase: 5
Type: QOS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ciscoasa#
ciscoasa# show xlate
2 in use, 11 most used
Flags: D - DNS, e - extended, I - identity, i - dynamic, r - portmap,
s - static, T - twice, N - net-to-net
NAT from inside:192.168.1.200 to outside:192.168.1.240
flags sT idle 0:10:59 timeout 0:00:00
NAT from outside:44.44.44.44 to inside:192.168.1.240
in bellow I paste the firewall configuration
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.10.13.1 255.255.255.0
interface GigabitEthernet0/2
nameif outside
security-level 0
ip address 10.10.14.1 255.255.255.0
object network real_inside
host 192.168.1.200
object network real_outside
host 44.44.44.44
object network map_inside
host 192.168.1.240
object network map_outside
host 10.10.14.40
access-list out extended permit ip any any
access-group out in interface outside
router ospf 1
network 10.10.13.0 255.255.255.0 area 0
default-information originate
route outside 0.0.0.0 0.0.0.0 10.10.14.4 1
2 Accepted Solutions
Your example only changes the source. A Twice NAT rule basically lets you identify the source and destination address in a NAT rule, which is what you've configured except you haven't changed the destination IP address.
One scenario when you would change the destination IP address could be if your client devices are configured to use Google DNS 8.8.8.8 but you want to redirect any traffic destined to 8.8.8.8 to another provider such as Cisco Umbrella (207.67.222.222). NAT rule example:-
nat (inside,outside) source static real_inside map_inside destination static GoogleDNS UmbrellaDNS
The NAT ip address you use needs to be routable from the destination, so if the firewall is connected to the internet you would need to NAT to a public IP address. If the firewall is located on a private WAN and the destination device can route to a private IP address then that will obviously work.
6 Replies 6
You are communicating with 44.44.44.44, in your current configuration you have defined the original destination as map_inside (192.168.1.240), the original and translated destination should be the same.
nat (inside,outside) source static real_inside map_inside destination static real_outside real_outside
This will translate source from 192.168.1.200 to 192.168.1.240 when the destination is 44.44.44.44
thanks Dear
your solution works but is this change the source and destination in this solution ?and is this same as Twice NAT ?
one more question in which scenario we use different destination address at the end of script ?
Thank You so much Dear RJI
I test and it work perfect ,I just post the details of the topology it might help somebody in future
in this topology if somebody want to reach the google DNS (8.8.8.8) from inside host , ASA will redirect the packets to destination which we will define and send the packet back to the WEB server (Web server don't know the IP address of destination and only set google DNS as destination )
Debug on Router R4  in outside (Loopback 44 : 44:44:44:44 )
final NAT configuration :
Host 192.168.1.200
Host 192.168.1.240
object network googledns
host 8.8.8.8
object network ciscoum
host 44.44.44.44
nat (inside,outside) source static real_inside map_inside destination static googledns ciscoum
Dear RJI
one more question comes in my minds is that regarding to real word design ,how we should choose this IP address n real world network  for map_inside  IP , since in this topology i have default route for return route to firewall , do we need to choose this IP in private range of our organization , I would appreciate to clear it for me.
Host 192.168.1.240
