Problem with Hosts/Networks on my PIX 515e
m_burutzis
I have a Pix 515e as my firewall. We had a power failure last night and when I checked the config trough the PDM, I noticed that on my external ethernet card, I had lost my adresses, even tho it was saved to flash. I put them back since, and I can only ping the primary adress on the card. I have 5 more adresses and none respond. The other cards respong well from the internal network and DMZ.
Anyone have an idea how to get my IP's back up?
Thanks in advance
osam
Yes, sometimes PIX does that. I think it is a bug..
You may need to issue "clear ip" and configure your ips again. Try it out!
"Clear ip" will clear PIX interfaces IP addresses to 127.0.0.1, so, make sure you have them documented.
