Problem with import IPS 5.1 sensor into IPS MC 2.2
k.lapczuk
During the import I get the following error:
10.1.1.51: Import
Import failed due to exceptionError importing configuration files from the sensor - Unable to import sensor config using RDEP: java.lang.Exception: An exception occurred during the import of file(webServer), detail=An error occurred getting signature catagories, detail=For input string: ""
The input fails. Is there any way to import the sensor to the MC?
Best regards,
Krzysztof
attmidsteam
We ran into this awhile back, and had to open a TAC for resoution. If I recall, this is related to the new av notation associated with the sensor version. Did you just upgrade the sensor (5.1(?) ) Which signature pack are you on?
In fact, three days ago I installed service pack to CW2k VMS IPMC. It helped.
What was your solution?
Best regards,
Krzysztof
jeremy_liao
is there any way to solve it ?
