Problem with interface PAT in ASA 8.4
esanvalero
Level 4
Level 4
Hi.
I've an ASA5505 running 8.4 firmware
I'm trying to configure access to an internal FTP server using the same IP address we have in the outside interface.
The configuration is as follows:
object network FTP
host 192.168.125.32
object network FTP
nat (inside,outside) static interface service tcp ftp ftp
access-list outside_access_in line 3 extended permit tcp any object Fax eq ftp  log default
... But it doesn't work ...
If I use any other public accesible IP to do the NAT it works fine. For example:
     object network Fax
        nat (inside,outside) static 44.44.44.44 service tcp ftp ftp
So, is it not possible to use the outside interface of the ASA to redirect a port to an internal service??
5 Replies 5
gouravbathla
It is not correct
it should be
access-list outside_access_in line 3 extended permit tcp any object FTP eq ftp  log default
Try with this
Rate this if it is helpful..
esanvalero
Level 4
Level 4
Hi Gourav.
You are right. I made a mistake while copying the lines. But the problem persist with the changes you mention.
please provide your running config output .
epasqualotto
Hi, I've the same issue with FTP on outside interface (other IP works well). Have you found any workaround? I'm running on 8.4.6
Hi.
I haven't found a solution. Finally I had to use other IP address than the one used by the outside interface.
