Problem with pix 501
n.ruggero
Community Member
I have installed a pix 501 to protect my web and mail servers inside a network divided in two lan
192.168.1.0/24 (the secure one-inside)
192.168.2.0/24 (outside)
I have many client on 192.168.2.x (outside) and I want to control access to my web and mail servers by the intranet
The outbound interface is is directly connected to a hub-port on which I have also my pc client
The Intbound interface is is directly connected to a hub-port on which I have also my servers
Mail server have Ip 192.168.1.30/24
Www server have Ip 192.168.1.23/24
When I try to connect to my servers from any pc on lan 192.168.2.x to take mail or browse I have no response without error messages on firewall
The firewall configuration is:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
access-list 100 permit tcp any host 192.168.2.30 eq pop3
access-list 100 permit tcp any host 192.168.2.30 eq smtp
access-list 100 permit tcp any host 192.168.2.23 eq www
interface ethernet0 10baset
interface ethernet1 10full
ip address outside 192.168.2.40 255.255.255.0
ip address inside 192.168.1.40 255.255.255.0
global (outside) 1 192.168.2.100-192.168.2.110
global (outside) 1 192.168.2.111
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 192.168.2.30 192.168.1.30 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.2.23 192.168.1.23 netmask 255.255.255.255 0 0
access-group 100 in interface outside
There is anyone that can help me?
5 Replies 5
turnbull
Level 4
Level 4
try " sysopt noproxyarp inside "
KEVIN STEWART
Level 2
Level 2
Depending on the License, I thought the PIX 501 was limited to either 10 or 50 users, I am not entirely sure how this is enforced, but you might be hitting this limit...show version will show you the limit..
s
ajd
hubs dont do full duplex 😃
set the interfaces to auto of 10half.
-ne1secure?
n.ruggero
Community Member
Thanks to all
I've resolved my problem adding a static Route to my server Mail/Web
