problem with remote access vpn
prashantrecon
Level 7
Level 7
Hi All,
I am facing slow connectivity issues when connected to remote access vpn.
Able to do RDP to the server intially it works fine once i excute some queries or commands  it freezes.
speed is also good.when pinged to far end peer ip from windows machine displays packets needs to fragemented but df set
shall i change tcp-mss value.If i do does it have any reverse affect on other traffic.
30 Replies 30
Still change it
Can I see the packet-shaper
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
