Problem with routing voice isp
sirjohnbeano
Community Member
Hi Guys,
I want to add a SIP trunk on my existing network. My ISP offers me on there switch 2900 with a single IP which i have to lead to my 3cx configuration on a HyperV.
What configuration do I need to make, to route the voice via the separate voice network ?
Help appreciated.
Thanks in advance.
Beano
Julio Carvajal
So you wan to send SIP and the RTP traffic over the SIP Provider but the internet traffic over another link? Is that true??
The ASA does not support PBR where you can route based on source traffic or application being used so in this case you will need to still depend of the routing table of the ASA.
Maybe I am understanding wrong the question, can u be a little more clear and specific?
Looking for some Networking Assistance?
Contact me directly at [email protected]
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Julio,
Correct, Send SIP and the RTP traffic over the SIP Provider but the internet traffic over another link.
Every voip traffic from this SIP provider need to be routed to 172.xx.xx.250
rgs,
Beano
First of all is important to say that this is not officially supported as PBR is not yet implemented on ASA firewalls.
There are some tweaks that you can do to try to make this happens (not 100% sure if will work due to the nature of this protocol opening pinholes) and of course would not recommended for any real scenario.
My best recommendation is to place a router in front of the Firewall (Just forwarding all traffic, no NAT being done there but performing the PBR for you).
Cheers,
Julio Carvajal
