Problem with Verisign SSL used with ASDM
k-al-mutawa
I had purchased a Verisign SSL key to be installed on PIX 535 IOS 7.22 using ASDM 5.22
I followed the document "VeriSign SSL Certificate Installation to the Cisco ASA Using ASDM" Document ID: 81558
when I access https://pix_int_IP
I get a certificate error "The certificate had expired or is not yet valid"
although the date on it is 7/11/2007 to 7/11/2008
Please help me.
ivillegas
Level 6
Level 6
Revoke the existing certificate and install the new certificate.
After I had made Verisign SSL cert work on PIX535 IOS 7.22, when many users had to access the SSL cert the pix had reloaded and all the cert config lines had disapear!
Does IOS 7.07 support Verisign SSL cert and is it stable that can handle users when using SSL with AAA raduis authentication?
