problems logging into PIX with SSH
augeiss
Community Member
Hi there,
I have a PIX 506 running OS 6.2(2) which is in a DMZ, known as the outside PIX. It is behind another PIX506 (the inside PIX). Both PIX have Tacacs+ configured for login authentication.
Last week the outside PIX crashed physically and I have replaced it with a spare PIX and reconfigured it entirely.
Now I cannot log on to this outside PIX using SSH, despite the access-list on the inside PIX is correct and permits both SSH and tacacs+. However I can telnet to it.
I am using Putty to connect and when I start the SSH session the login window of the PIX appears and immediately disappears without me having the time to do anything.
Any help would be greatly appreciated. Many thanks in advance.
A.G.
The inside PIX config :
access-list inside permit tcp Company-Inside-Net 255.255.255.0 host outsidepix-inside-interface eq ssh
access-list inside permit tcp Company-Inside-Net 255.255.255.0 host outsidepix-inside-interface eq telnet
access-list inside permit icmp Company-Inside-Net 255.255.255.0 DMZNet 255.255.255.192 echo
access-list inside permit icmp Company-Inside-Net 255.255.255.0 DMZNet 255.255.255.192 echo-reply
access-list dmzacl permit icmp host outsidepix-inside-interface Company-Inside-Net 255.255.255.0 echo
access-list dmzacl permit icmp host outsidepix-inside-interface Company-Inside-Net 255.255.255.0 echo-reply
access-list dmzacl permit tcp host outsidepix-inside-interface host tacacs-server1 eq tacacs
access-list dmzacl permit tcp host outsidepix-inside-interface host tacacs-server2 eq tacacs
The outside PIX config :
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ (inside) host tacacs-server1 1234 timeout 10
aaa-server TACACS+ (inside) host tacacs-server2 1234 timeout 10
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authentication telnet console TACACS+
aaa authentication ssh console TACACS+
aaa authentication enable console TACACS+
telnet Company-Inside-Net 255.255.255.0 inside
telnet timeout 5
ssh Company-Inside-Net 255.255.255.0 inside
ssh DMZNet 255.255.255.192 inside
ssh timeout 5
mostiguy
Level 11
Level 11
did you follow the steps for setting up ssh? is the hostname and domain name defined on it? did you ca generate rsa... to create the encryption keys?
mostiguy
Level 11
Level 11
augeiss
Community Member
ah yes...
Thanks very much that did the trick, i had forgotten the rsa key generation and save... now it is working perfectly...
Many thanks
