Problems to call on a Videoconference System
anunes1987
Community Member
Hello Guys !
Need your help to solve an issue.
I have a Videoconference system which calls another Videoconference in another site , this communication is done thru a leased line between these two sites.
DMZVCA ---- ASA-A --- LEASED LINE ---- ASA-B ----- DMZVCB
From DMZVCB i can make calls and all works fine but from DMZVCA i'm unable to call them.
When i got the log seems to be a NAT problem on ASA A but i'm not sure what could i do. I know the problem is related to the ASA A but i can't get what is the issue if a need to put up a PAT dunno.
If i put up the log on i get a translation failure related to the NAT from DMZ to the inside someone can give me some hints about how to solve this issue?
My VC IP address is 172.16.10.200
Following some outputs:
interface GigabitEthernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 172.16.30.1 255.255.255.0
interface GigabitEthernet0/2.2>> My DMZ
vlan 4
nameif dmz2
security-level 4
ip address 172.16.10.1 255.255.255.0
sh run nat
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.16.30.201 255.255.255.255
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz2) 0 access-list dmz2_nat0_outbound
SPOFWL01# sh run global
global (outside) 1 interface
global (dmz1) 1 interface
global (dmz2) 1 interface
SPOFWL01# sh run stat
static (dmz2,outside) tcp 189.39.32.42 www 172.16.10.22 82 netmask 255.255.255.255
static (dmz2,outside) tcp 189.39.32.41 www 172.16.10.22 81 netmask 255.255.255.255
static (dmz2,outside) tcp 189.39.32.40 https 172.16.10.22 https netmask 255.255.255.255
static (dmz2,outside) tcp 189.39.32.40 www 172.16.10.22 www netmask 255.255.255.255
static (dmz2,outside) tcp 189.39.32.37 www 172.16.10.200 www netmask 255.255.255.255
static (inside,dmz2) 172.16.1.21 172.16.30.21 netmask 255.255.255.255
static (inside,dmz2) 172.16.1.22 172.16.30.22 netmask 255.255.255.255
static (inside,dmz2) 172.16.1.71 172.16.30.71 netmask 255.255.255.255
static (inside,outside) 189.39.32.39 172.16.30.225 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.11 10.21.8.11 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.21 10.21.8.21 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.32 10.21.8.32 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.71 10.21.8.71 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.76 10.21.8.76 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.22 10.21.8.22 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.91 10.21.8.91 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.25 10.21.8.25 netmask 255.255.255.255
static (inside,dmz2) 10.21.8.77 10.21.8.77 netmask 255.255.255.255
static (dmz2,inside) 172.16.10.23 172.16.10.23 netmask 255.255.255.255
static (dmz2,outside) 189.X.X.X 172.16.10.25 netmask 255.255.255.255 dns
static (dmz2,inside) 172.16.10.22 172.16.10.22 netmask 255.255.255.255
static (dmz2,outside) 189.X.X.X 172.16.10.21 netmask 255.255.255.255
static (dmz2,inside) 172.16.10.200 172.16.10.200 netmask 255.255.255.255
static (dmz2,outside) 189.X.X.X 172.16.10.200 netmask 255.255.255.255
Please Give some hints, thanks in advance
Shrikant Sundaresh
Hi Amanda,
Could you please run a packet-tracer command on ASA-A to confirm if packets are allowed through?
The command would be:
packet-tracer input dmz2 tcp 172.16.10.200 detailed
Reply with the output of the command, and we can try troubleshooting the issue.
If you are unsure about which port numbers are to be used, then you can capture a few packets to find that out.
access-list capacl permit ip 172.16.10.200 any
capture capdmz access-list capacl interface dmz2
After a test call, do "show cap capdmz" to check which port it tried to communicate with DMZVCB on, and run the packet tracer for that destination port.
The output of this command will tell us if the packet is getting dropped and if so, why.
