Problems with ASA 5520
nachete1979
Hello all,
I am having dificulties migrating from a PIX to an ASA 5520 8.0(3).
I have the nat translations of the DMZs servers and the access list in the outside interface as see below:
access-list outside_access_in extended permit tcp any host FTP range ftp-data ftp
static (DMZ,outside) x.y.z.a FTP netmask 255.255.255.255
But when i try to connect to the outside natted address, the log says that the connection is denied due to the access list.
when I try a sh nat DMZ FTP, it says:
match ip DMZ host FTP outside any
static translation to x.y.z.a
translate_hits = 0, untranslate_hits = 52
It seems it is not being translated
Any ideas?
acomiskey
Level 10
Level 10
should be...
access-list outside_access_in extended permit tcp any host x.y.z.a range ftp-data ftp
acomiskey
Level 10
Level 10
should be...
Then, my question is, does the ASA work in a different way than the PIX regarding access-list?
I mean, does pix do first nat and later control and asa vice versa?
BR
No, they work the same way.
