Problems with NAT-ASA5505-ESXi
Rafael Jimenez
Level 4
Level 4
I have a ASA5505 with 1GB of RAM and the latest version of software.
I have several ESXi with vSphere 5.1. I want to put a VM with CentOS 5.x in the DMZ. The Centos machine works well if I define a PAT WITH the outside interface.
But when I configure static NAT 190.x.x.215 <-NAT-> 192.168.111.215 I have packet loss.
I also tried with Windows 7 and is exactly the same issue.
I tested with wireshark installed on the centos and all I see are out of sequence,  lost packets and retransmissions.
The physical configuration is:
Internet <-> ASA <-> inside <-> UC520 <-dot1qtrunk-> ws-3560 <-dot1qtrunk->vswitch<->ESXi.
The problem is not in the vm, I'm 99% sure it's something in the ASA.
Also discard the IP checksum offload both Linux and Windows.
I dont see any key message in the asa asdm log
Fragment of my config...
ASA Version 9.0(2)
hostname aaabbbcc
names
interface Ethernet0/0
description to ISP2 Modem (Claro)
switchport access vlan 200
speed 100
duplex full
interface Ethernet0/3
description Uplink to UC500
switchport access vlan 172
speed 100
duplex full
interface Vlan172
nameif inside
security-level 100
ip address 172.16.1.1 255.255.255.0
interface Vlan200
nameif claro
security-level 0
ip address 190.x.x.64 255.255.255.0
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network 172.16.1.x-network
subnet 172.16.1.0 255.255.255.0
object network 192.168.100.x-network
subnet 192.168.100.0 255.255.255.0
object network 172.16.1.x-claro-PAT-network
object network 192.168.100.x-claro-PAT-network
object network www-host
host 192.168.111.215
nat (inside,claro) static 190.x.x.215
object-group protocol tcp-udp
protocol-object tcp
protocol-object udp
object-group service web-mail-services tcp-udp
port-object eq domain
port-object eq www
access-list in-claro extended permit object-group tcp-udp any object www-host object-group web-mail-services
ip verify reverse-path interface inside
ip verify reverse-path interface claro
no arp permit-nonconnected
nat (inside,claro) dynamic interface
nat (inside,claro) static interface
access-group in-claro in interface claro
route claro 0.0.0.0 0.0.0.0 190.x.x.1 1
route inside 192.168.100.0 255.255.255.0 172.16.1.254 1
route inside 192.168.111.0 255.255.255.0 172.16.1.254 1
http server enable
http 172.16.1.0 255.255.255.0 inside
http 192.168.100.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
service resetinbound interface claro
telnet 172.16.1.0 255.255.255.0 inside
telnet 192.168.100.0 255.255.255.0 inside
telnet timeout 5
ssh 172.16.1.0 255.255.255.0 inside
ssh 192.168.100.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
I need some help, otherwise I had to take out the dmz and put a phisical server directly on internet.
Thanks.
Andrew Phirsov
Level 7
Level 7
Do the capture CAP1 type asp-drop all and you should see in that capture file what pakets asa drops and why it does so. Probably you'll be able to get smth from that.
Also i would disable scanning threat-detection and threat detection statistics, cause I assume ASA should be pretty much loaded performing those two.
