PROBLEMS WITH SAME ASA5520 VERSION 8.0.4
evucinovich
Frequent Visitor
Frequent Visitor
Hi, please i want to ask you if you know why is happen this. Y connect an ASA5520 en the network and it starts wotking good, the clients can navigate to internet, and then, the clients stops navigate, they can't get out to the asa. It coud be same bug of the version 8.0.4?? Thanks.
Regards.
Elias Vucinovich.
sadbulali
Level 8
Level 8
I think hat you might be hitting the bug CSCsk97671 (VPN client with NULL Encryption L2TP-IPSec behind NAT drops on 71st sec) which is causing the issue you are facing.VPN works without this issue when connected with 3DES encryption.Try using 3DES encryption.
