QOS problem Due to Transparent firewall
manik.palekar
I have deployed Transparent pix firewall between service provider Router (MPLS Network ) & My Core L3 switch.Service provider has defined QOS for VOIP & data.After deploying transparent firewall VOIP is going through default QOS .I have defined bandwidth through QOS but now its taking default path & My defined COS for voip is free.Please suggest on same .....Thanks in advance
ivillegas
Level 6
Level 6
QoS in transparent mode is an unsupported feature. It is supported only in Routed mode.
