RDP Access problem through ASA5510 FW
saroj pradhan
i  am  using Cisco ASA5510 Firewall  in my  Network in the distrubition Layer .
Private Range of Network Address  use  in the Network  and PAT  at the FW for  address translation.
presently  encountering an issue  the users  behind  the FW  in my network  unable to  RDP  at port 2000  presented  at the Client Network.
Able to Telnet  on port2000 but  not RDP .
Please advice  any changes needed at the FW end  to  get the RDP Access.
Saroj
12 Replies 12
Julio Carvajal
We need more information!!
Where are the clients? On the trusted or untrusted zone
Where is the RDP server?
Please post your configuration ( with some changes of course due to security purposes)
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
My users are behind the ASA Firewall in my Network and trying to access the Server through RDP the server Location is at USA.
No idea about client environment but the RDP works in Internet dada card, Through Checkpoint FW and Sonicwall Firewall .
Enclosed the Config File of ASA,
Saroj
Please provide following:
packet-tracer input inside tcp x.x.x.x (inside_user_Ip) 1025 y.y.y.y(RDP_server_ip) 2000
Julio Carvajal
Please find the report.
Netlink-OS-ASA# packet-tracer input inside tcp 172.16.48.213 1025 74.94.242.13$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 0.0.0.0 0.0.0.0 outside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in_1 in interface inside
access-list inside_access_in_1 extended permit ip any any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: inspect-skinny
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect skinny
service-policy global_policy global
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside) 1 Block_FromASA_ThroughUntangle1 255.255.255.192
match ip inside Block_FromASA_ThroughUntangle1 255.255.255.192 outside any
dynamic translation to pool 1 (122.168.191.66 )
translate_hits = 59925, untranslate_hits = 345
Dynamic translate 172.16.48.213/1025 to 122.168.191.66/29284 using netmask 255.255.255.255
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 9
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_out out interface outside
access-list outside_access_out extended permit ip any any
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 59535332, packet dispatched to next module
Phase: 12
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 122.168.191.65 using egress ifc outside
adjacency Active
next-hop mac address 0019.2f8e.c639 hits 29742
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Saroj
Hello Saroj,
everything looks good.
Please do captures in order to troubleshoot this, captures need it on the inside and outside interface.
http://analysisandreview.com/cisco/how-to-configure-a-packet-capture-in-the-cisco-asa/
http://www.techrepublic.com/blog/networking/easy-packet-captures-straight-from-the-cisco-asa-firewall/1317
Julio Carvajal
I have captured the Log from the ASA While conncting the RDP Server.
6
Feb 14 2012
07:19:39
302014
74.94.242.139
3389
172.16.51.10
48312
Teardown TCP connection 59541059 for outside:74.94.242.139/3389 to inside:172.16.51.10/48312 duration 0:00:00 bytes 0 TCP Reset-O
That is all we need.. Reset-O
A reset packet is comming from the outside, that is why we should create a packet-capture, we should have seen those packets comming from the server.
Connection is being closed by the RDP server!
Do rate all the helpful posts!!
Julio Carvajal
As  per your  instruction  I have configured on the ASA the following  command to capture packet  but  no result.
Showing 0 packet captured  while trying with RDP  On port 2000 ,
Saroj
access-list capin permit tcp host rdp_client_private_ip host server_outside eq 2000
access-list capin permit tcp  host server_outside eq 2000 host rdp_client_private_ip
access-list capout permit tcp host rdp_client_public_ip host server_outside eq 2000
access-list capout permit tcp host server_outside eq 2000 host rdp_client_public_ip
capture capin access-list capin interface inside
capture capout access-list capout interface outside
i am unbale  to capture  log  due to performance issue .
please find the report.
Netlink-OS-ASA# capture capin access-list capin interface inside real-time dum$
Warning: using this option with a slow console connection may
         result in an excessive amount of non-displayed packets
         due to performance limitations.
Use ctrl-c to terminate real-time capture
0 packets shown.
0 packets not shown due to performance limitations.
hello,
please find the output of the capture packet from  the inside Interface.
   1: 13:50:54.278138 [|ip]
   2: 13:50:54.592666 [|ip]
   3: 13:50:54.593902 [|ip]
   4: 13:50:54.594329 [|ip]
   5: 13:50:54.594390 [|ip]
   6: 13:51:20.340390 [|ip]
   7: 13:51:20.340467 [|ip]
   8: 13:51:20.657848 [|ip]
   9: 13:51:23.381877 [|ip]
  10: 13:51:23.696527 [|ip]
  11: 13:51:23.697717 [|ip]
  12: 13:51:23.698495 [|ip]
  13: 13:51:23.698557 [|ip]
  14: 13:51:36.024519 [|ip]
  15: 13:51:36.024595 [|ip]
  16: 13:51:36.345120 [|ip]
  17: 13:51:38.761892 [|ip]
  18: 13:51:39.074260 [|ip]
  19: 13:51:39.075054 [|ip]
  20: 13:51:39.075496 [|ip]
  21: 13:51:39.075557 [|ip]
  22: 13:52:27.816180 [|ip]
  23: 13:52:27.816257 [|ip]
  24: 13:52:28.132561 [|ip]
  25: 13:52:31.949459 [|ip]
  26: 13:52:32.265367 [|ip]
  27: 13:52:32.266267 [|ip]
  28: 13:52:32.267060 [|ip]
  29: 13:52:32.267121 [|ip]
29 packets shown.
Netlink-OS-ASA# sh capture capin access-list capin detail
82 packets captured
0 packet shown
when i tried to capture  from outside interface  no data shown.
Netlink-OS-ASA# capture capout access-list capout interface outside real-time
0 packets shown.
please help me resolved the RDP Issue.
Please  help  to get a resolution.
ThanKS,
SAROJ
