recommended solution for ARP packet
zakid
hi folks,
I want to deny or block,   an ARP packet received in cisco firewall. I have cisco IPS enabled in front of firewall.
can any one guide me.
regards,
basha.
5 Replies 5
praprama
I noticed you have a similar question posted on the Firewall community as well. On the IPS unfortunately, there is no such way of doing such a thing if we are indeed referring to the same syslog message.
Thanks and Regards,
Prapanch
You can use arp access-list on the switch, or you can use dhcp snooping.
For the ASA you can use arp inspection in transparent firewall (it will not block an arp though).
I hope it helps a little.
PK
hi team,
I am little bit confused about the solution.
My firewall is used in route mode.
if we clear little bit, much appriacted.
regards,
In routed mode unfortunately there is no way to do that. Please post the exact syslog message you are getting.
Thanks and regards,
Prapanch
HI team,
sorry for that, reason, little bit confusing where to post. later i decided and  noticed and moved this threat to firewall community.
regards,
