Redundancy when connecting two switches to FTD??
FTD is operating in ASA mode.
Unfortunately, FTD does not support redundant interfaces.
Any ideas on a design that provides redundancy when connecting two SWs to an FTD?
@JustTakeTheFirstStep if the switches are a stack or using StackWise Virtual or VSS or VPC then you can connect FTD interfaces within the same EtherChannel to separate switches in the VSS/vPC or VSL.
https://www.cisco.com/c/en/us/td/docs/security/firepower/650/fdm/fptd-fdm-config-guide-650/fptd-fdm-interfaces.html#id_111440
