Router 1941 - problem AES, DES
jeromele
Community Member
Cisco 1941-SEC / K9 IOS 15.2 (2) T1 router
R1(config)#crypto isakmp policy 10
R1(config-isakmp)#encryption ?
3des Three key triple DES
aes AES - Advanced Encryption Standard
des DES - Data Encryption Standard (56 bit keys).
What is their operation encryption mode? (e.g. CBC - Cipher Block Chaining or CTR - counter) I can't find it anywhere. I need it extremely (thesis). If you dont know, maybe you know someone, who can help/
It will be AES CBC, reference here. When using IKEv2 you can use AES GCM.
balaji.bandi
i do not believe that support
check the feature support :
https://cfn.cloudapps.cisco.com/ITDIT/CFN/
BB
