RVPN problem with ASA 5510
preddy
ASA 5510 with OS ver 7.2(1), it is not allowing to pass the traffic thru tunnel for more than two RVPN tunnels. Ping, RDP everything works fine for 2 tunnels. From 3rd tunnel will get established, but will pass only sent traffic, no return traffic. I believe it taking WebVPN client access licensing is taking into count for IPSec VPN's also.
Can anybody suggest the solution for this problem.
Thanks "N" Regards,
P R Reddy
