same arp entries on inside and outside
lcaruso
Level 6
Level 6
I was having a problem pinging across a site to site vpn tunnel to this site, then I noticed the same inside devices showing up on the inside and outside during a show arp command.
This is ASA 8.4(2) 5505.
Is this a bug or what would cause this? Thanks.
MIL-ASA5505# sh arp
         inside 192.168.25.135 000f.a600.1c35 5
         inside 192.168.25.16 0016.41ea.0470 49
         inside 192.168.25.247 000e.b640.71d8 89
         inside 192.168.25.14 0023.ae88.2f4e 112
         inside 192.168.25.130 0013.723e.7868 129
         inside 192.168.25.3 0022.75ba.3a4b 188
         inside 192.168.25.81 0023.1471.3574 223
         inside 192.168.25.18 0025.64e7.960d 238
         inside 192.168.25.22 001c.2320.988b 257
         inside 192.168.25.13 0024.e8a3.c98a 273
         inside 192.168.25.37 0008.7420.7990 446
         inside 192.168.25.63 0025.564f.b1ae 470
         inside 192.168.25.132 0001.f000.0fc6 733
         inside 192.168.25.80 0026.b9b8.fe12 1577
         inside 192.168.25.222 0020.6b66.a4ff 1833
         inside 192.168.25.140 00e0.98b4.6878 3300
         outside 192.168.25.14 0023.ae88.2f4e 112
         outside 192.168.25.130 0013.723e.7868 129
         outside 192.168.25.133 00c0.a888.e73d 181
         outside 192.168.25.3 0022.75ba.3a4b 188
         outside 192.168.25.81 0023.1471.3574 223
         outside 192.168.25.18 0025.64e7.960d 238
         outside 192.168.25.135 000f.a600.1c35 247
         outside 192.168.25.22 001c.2320.988b 257
         outside 192.168.25.13 0024.e8a3.c98a 275
         outside 192.168.25.16 0016.41ea.0470 279
         outside 192.168.25.37 0008.7420.7990 449
         outside 192.168.25.132 0001.f000.0fc6 735
         outside 192.168.25.80 0026.b9b8.fe12 1580
         outside 192.168.25.222 0020.6b66.a4ff 1836
         outside 192.168.25.247 000e.b640.71d8 2038
         outside 192.168.25.131 0001.f000.0fc5 2050
         outside 192.168.25.140 00e0.98b4.6878 2410
         outside 192.168.25.63 0025.564f.b1ae 10667
Maykol Rojas
Larry,
Is the switch on the outside connected to the switch on the Inside? Are you using only 1 switch? If so, is everything on the same vlan?
Mike
Mike
Maykol Rojas
Larry,
Mike
Mike
Hi Mike,
Those are the right questions to ask. I've passed them along to the onsite resource to see what we can find out.
Thanks much.
Hi Mike,
Thanks much.
