Same security level interface ACL
ncowger
Level 3
Level 3
On a Cisco ASA 5520.  I have 2 interfaces that are the same security level. I need hosts on 1 of these interfaces to be able to get to a specific IP and port on the other but I DON'T want to blanket enable 'same-security-traffic permit inter-interface"  I have added an ACL inbound on the interface allowing the desired traffic and inbound on the other for return traffic and it simply doesn't work.
interface GigabitEthernet0/3.175
 vlan 175
 nameif Test175
 security-level 30
 ip address 172.30.175.1 255.255.255.0
interface GigabitEthernet0/3.185
 vlan 185
 nameif Test185
 security-level 30
 ip address 172.30.185.1 255.255.255.0
access-list Test185 extended permit udp any host 172.20.175.52 eq ntp
access-group Test185 in interface Test185
access-list Test175 extended permit udp host 172.20.175.52 eq ntp any
access-group Test175 in interface Test175
13 Replies 13
vabruno
Level 3
Level 3
Can you post your whole config? Need to look at your NAT policy
There is no NAT between the two.
may all of your LAN is PATed to the public IP(or interface). Then you should exclude NAT for the communication between these two interfaces.
Vipin
Thanks and Regards, Vipin
vipinrajrc
Level 6
Level 6
Yes, may be NAT need to be disabled for the communication between these two interface.
Please post your configuration
If I move the source interface up a security level it works so it's not NAT related as the source interface has no NAT configurations.
VPN# packet-tracer input JMSTest185 udp 172.30.85.10 123 172.30.175.52 123 det
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0x7b4060b0, priority=1, domain=permit, deny=false
        hits=2612, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=JMSTest185, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.30.175.0    255.255.255.0   JMS
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0x79336a28, priority=11, domain=permit, deny=true
        hits=1365, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: JMSTest185
input-status: up
input-line-status: up
output-interface: JMS
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
VPN#
I notice in the packet tracer you used 172.30.85.10 as your source address but the interface uses 172.30.185.0/24.  Is this the correct host and if so, is there a route for the 172.30.85.X network on the JMSTest185 interface?
Is NAT control enabled?  With the 'same-security-traffic permit inter-interface' command in place, traffic should be allowed to traverse the two same-security interfaces without NAT (even if NAT control is enabled) as long as the correct access-list entries are in place.
Yes.  You are right.  But with the correct IP it still fails.
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
        hits=2837, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
The first rule to be hit will always be the same-security-traffic implicit rule. If you want to filter this you can do one of 2 things.
1-Lower one of the interfaces security levels and use ACLs to permit the traffic
2-Put the command same-security-traffic permit inter-interface and then filter the traffic between them using ACLs.
There is a third one, but is related to NAT and since you dont have nat configured it will be better to leave it as it is.
Mike.
Mike
So wait, is the packet-tracer output you provided with'same-security-traffic permit inter-interface' enabled?  The packet-tracer output is what I would expect to see without the command.  It has to be there if you want to leave the security levels the way they are.
I'm kinda suprised there isn't a way to allow the traffic via an ACL...  Thanks everyone for your input.
It is, but you will need to add the same security traffic first. That would be the first rule to be hitted, then what you need to do is to filter the rest with ACLs.
Mike.
Mike
mudjain
Level 2
Level 2
If you dont want an other host to communicate with any other IP on the same security level interface you can use ACL to limit this, and then use same security-level inter-interface command and life remains good, if I understand logic of not using  the command .
