Scanning problem
Stephane Gros
Community Member
I have a remote site with 5 peoples with ASA 5505 just behind the ISP router.
I keep observes message like this in my syslog servers.
Nov 26 09:42:21 Nov-******** 26 2012 09:42:21: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4344
Nov 26 09:42:41 Nov-******** 26 2012 09:42:41: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 3 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4371
Nov 26 09:43:01 Nov-******** 26 2012 09:43:01: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4359
Nov 26 09:43:21 Nov-******** 26 2012 09:43:21: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 3 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4355
Nov 26 09:43:41 Nov-******** 26 2012 09:43:41: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 3 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4372
Nov 26 09:43:41 Nov-******** 26 2012 09:43:41: %ASA-4-733100: [ Scanning] drop rate-2 exceeded. Current burst rate is 0 per second, max configured rate is 8; Current average rate is 7 per second, max configured rate is 4; Cumulative total count is 26008
Nov 26 09:44:01 Nov-******** 26 2012 09:44:01: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4311
Nov 26 09:44:21 Nov-******** 26 2012 09:44:21: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 3 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4312
Nov 26 09:44:41 Nov-******** 26 2012 09:44:41: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 7 per second, max configured rate is 5; Cumulative total count is 4282
My conf for the threat part is based on default config for "threat detection" :
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
I'm in versions:
-ASA Version 8.4(4)1
-asdm-649-103.bin
But I've configured some service policy to have compression with internal equipment between this site and the datacenter, and to allow the user to ping and ftp everywhere:
tcp-map MY_tcpmap
  queue-limit 20 timeout 4
  synack-data allow
  invalid-ack allow
  seq-past-window allow
  tcp-options range 26 26 allow
  tcp-options range 28 28 allow
  no ttl-evasion-protection
  urgent-flag allow
access-list inside-mpc_1 extended permit ip object-group INTERN_SUBS object-group REMOTE_VPN_SUBS
class-map ipe-compress-class
match access-list inside-mpc_1
access-list inside_mpc extended permit ip object INTERN_SUB1 object INTERN_SUB2
class-map inside-class
match access-list inside_mpc
policy-map inside-policy
class inside-class
  set connection advanced-options tcp-state-bypass
class ipe-compress-class
  set connection random-sequence-number disable
  set connection advanced-options MY_tcpmap
service-policy inside-policy interface inside
class-map icmp-class
match default-inspection-traffic
class-map ftp-class
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map icmp_policy
class icmp-class
  inspect icmp
class ftp-class
  inspect ftp
service-policy icmp_policy interface outside
When I'm looking with ADSM the debugging view, I see a lot of broadcast issued by one of the computer. I think the problematic software is Dell Stage and I'm working with the user to remove it.
But even if this problematic user is not at office, there is that kind of message.
Can someone help me to identify the bad traffic ?
Please tell me if you need more informations.
Best regards
Stephane Gros
Community Member
Hi everyone,
I still observe these message in my syslog permanently.
Dec  3 04:34:50 Dec-****** 03 2012 04:34:50: %ASA-4-733100: [ Scanning] drop rate-2 exceeded. Current burst rate is 0 per second, max configured rate is 8; Current average rate is 8 per second, max configured rate is 4; Cumulative total count is 30079
Dec  3 04:35:10 Dec-****** 03 2012 04:35:10: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 8 per second, max configured rate is 5; Cumulative total count is 4945
Dec  3 04:35:30 Dec-****** 03 2012 04:35:30: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 3 per second, max configured rate is 10; Current average rate is 8 per second, max configured rate is 5; Cumulative total count is 4929
Dec  3 04:35:50 Dec-****** 03 2012 04:35:50: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 8 per second, max configured rate is 5; Cumulative total count is 4945
Dec  3 04:36:10 Dec-****** 03 2012 04:36:10: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 4 per second, max configured rate is 10; Current average rate is 8 per second, max configured rate is 5; Cumulative total count is 4954
Dec  3 04:36:31 Dec-****** 03 2012 04:36:31: %ASA-4-733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 3 per second, max configured rate is 10; Current average rate is 8 per second, max configured rate is 5; Cumulative total count is 4960
It's very annonying...
The only thing I can add is:
****# sh asp drop
Frame drop:
  NAT-T keepalive message (natt-keepalive)                                 86325
  IPSEC tunnel is down (ipsec-tun-down)                                     1456
  Punt no memory (punt-no-mem)                                               118
  Invalid encapsulation (invalid-encap)                                      379
  Invalid IP header (invalid-ip-header)                                        6
  Invalid IP length (invalid-ip-length)                                        2
  Reverse-path verify failed (rpf-violated)                                    1
  Flow is denied by configured rule (acl-drop)                           1501067
  Invalid SPI (np-sp-invalid-spi)                                             10
  First TCP packet not SYN (tcp-not-syn)                                   13218
  TCP data send after FIN (tcp-data-past-fin)                                  5
  TCP failed 3 way handshake (tcp-3whs-failed)                             15380
  TCP RST/FIN out of order (tcp-rstfin-ooo)                                67556
  TCP SEQ in SYN/SYNACK invalid (tcp-seq-syn-diff)                             6
  TCP SYNACK on established conn (tcp-synack-ooo)                             11
  TCP packet SEQ past window (tcp-seq-past-win)                             9154
  TCP invalid ACK (tcp-invalid-ack)                                            2
  TCP Out-of-Order packet buffer full (tcp-buffer-full)                    35094
  TCP Out-of-Order packet buffer timeout (tcp-buffer-timeout)                155
  TCP RST/SYN in window (tcp-rst-syn-in-win)                                  20
  TCP dup of packet in Out-of-Order queue (tcp-dup-in-queue)                2258
  TCP packet failed PAWS test (tcp-paws-fail)                                  7
  Slowpath security checks failed (sp-security-failed)                   1769202
  ICMP Inspect seq num not matched (inspect-icmp-seq-num-not-matched)          5
  FP L2 rule drop (l2_acl)                                                    53
  Dropped pending packets in a closed socket (np-socket-closed)            16945
Last clearing: 04:24:15 EST Nov 13 2012 by enable_15
Flow drop:
  Need to start IKE negotiation (need-ike)                                 14146
  NAT reverse path failed (nat-rpf-failed)                                    56
  Inspection failure (inspect-fail)                                          128
  SSL bad record detected (ssl-bad-record-detect)                            194
  SSL handshake failed (ssl-handshake-failed)                                  6
  SSL received close alert (ssl-received-close-alert)                          7
Can anyone help me to debug this ?
Best regards
