Set Interface Index Persistence on Cisco ASA 554x
LabRedesNet
I have a network monitoring tool that fails after my FW restart because the SNMP MIB IfIndex changes everytime it reboots.
Searching on Cisco.com I see there is a feautre available on snmp-server config http://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/28420-ifIndex-Persistence.html but I am not able to find out that option.
Firewall(config)# snmp
Firewall(config)# snmp?
configure mode commands/options:
snmp snmp-map snmp-server
Firewall(config)# snmp-ser
Firewall(config)# snmp-server ?
community Configure the community string
contact Text for mib object sysContact
enable Enable/Disable snmp-server or particular traps
group Define User Security Model Group
host Specify hosts to receive SNMP traps and send SNMP polls
listen-port Configure the SNMP engine's listening port
location Text for mib object sysLocation
user Define a user who can access the SNMP engine
Firewall(config)# snmp-server if
Firewall(config)# snmp-server if?
ERROR: % Unrecognized command
Firewall(config)# snmp-server enab
Firewall(config)# snmp-server enable
FW1-JC(config)# snmp-server enable ?
traps Configure traps
<cr>
My hardware is the following
Compiled on Fri 30-Aug-13 19:48 by builders
System image file is "disk0:/asa847-k8.bin"
Config file at boot was "startup-config"
Hardware: ASA5540, 2048 MB RAM, CPU Pentium 4 2000 MHz
Internal ATA Compact Flash, 256MB
Where is located that option?
Thank you.
Hello
it seems that a request for enhancement is opened at cisco :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtx33616
rgds
Guillaume
rate if uselful !
I understand from the mentioned link CSCtx33616 above that it means "it is not a bug it is a feature". It is a phrase used if you do not want to fix some issue.
I have the same problem with Cisco Firepower 2100 device. So manual changing of SNMP indexes after every reboot is necessary. Do you still like Firepower firewalls?
What monitoring tool are you using?
We use WhatsUp Gold. But all monitoring tolls would be confused if the index is different. Theoretically, the SW can compare interfaces by other parameters (speed, MAC address etc) and prepare a list old index <> new index. Much easier is that the monitored systems use the same index as it was used before reboot.
