Setup problem with ASA5505
huwyhuwy123
Level 3
Level 3
I've been asked to setup an ASA5505 for the first time. I've not had any experience with the ASA's and can't seem to get it working.
Presently I can ping google (66.249.93.99) from the ASA (via hyperterminal) however I can't ping out from a host on the internal network (192.168.1.26).
I'm guessing that the NAT setup is wrong..? Can someone take a look at the attached config and point me in the right direction?
TIA,
H
8 Replies 8
andrew.prince
Level 11
Level 11
You NAT looks OK - but your dhcp does not have a DNS entry? How are you pinging google, by IP or name?
By IP (66.249.93.99)
can you ping the IP from the host on the inside - and on the asa post the output of "show xlate"
Cheers Andrew.
I can't ping the IP from the inside - only from the ASA itself. Show xlate is below.....
0 in use, 1 most used
-H
Sorry - I missed something critical, add the below and re-test:-
access-list acl-outside extended permit icmp any any echo-reply
access-list acl-outside extended permit icmp any any unreachable
access-list acl-outside extended permit icmp any any traceroute
access-list acl-outside extended permit icmp any any time-exceeded
access-group acl-outside in interface outside
Thats great Andrew. I didn't realise you had to explicitly allow the traffic back in. All working.
Can I be cheeky and ask 1 more question..?
I need to setup port forwarding to a citrix server. Presumably I need to add port 1494 to "acl-outside" but I'm not sure what the static NAT command should be - can you help?
Don't worry - I worked it out. thanks for your help!
OK - glad to help.
